There are three questions below about TLC5941.
I would appreciate your advice.
- Although SCLK and GSCLK are written to be 30 MHz (max), how much is a Min value?
- When BLANK is "H", is a PWM setup of GS also reset?
※For example, although I think whether "GS Register" is reset with the system block diagram of the 1-page of the data sheet, is "12-Bit Grayscale PWM controll" reset,too?
- Is GND connection good when not using XERR?
Thank you for your consideration.
