I am planning to use the LM2587 in an non-isolated boost converter application. The LM2587 datasheet only provides example circuit, but it does not explain how to calculate the compensation capacitor and resistor. I know the error amplifier is a transconductance amplifier, but how to figure out the overall loop-gain and phase margin? Yes, I know I can use the WEBENCH Designer, but it only shows the result. What I want is a more technical explanation on how those R and C are calculted, for example, using Bode Plots and small signal AC analysis with poles and zeros etc.
