Hi everyone
my board could output audio signal with tps65950,now i instead it of tps65930.using the same driver ,but the audio couldn't output.
It's said that the software of tps65950 compatible with tps65930. if there was some difference between tps65950 and tps65930 to the audio driver?
if i want to handle the tps65930 to output audio signal,what should i change in tps65950 audio driver? i'm using the android2.3.4 beagleboard-xm
thanks &BR
