Opto-coupler usage in TL3844 flyback SMPS
Other Parts Discussed in Thread: TL3844, TL431
Hello
please analyse the feedback circuit shown below. It considers disabling the error amplifier (by grounding the FVB input) and controlling its output with the opto-coupler at the 0.5 mA COMP node:
It assumes RA will modulate a control voltage on the COMP node, based in the 0.5 mA current source shown in
Could you please check whether the suggested feedback concept works, or not?
If not, I ask you for the best recommendation regarding pulse width modulation based on a typical TL431-OPTOCOUPLER feedback & TL3844. There is no data about using a TL3844 with TL431 and opto-coupler.
Thanks in advance
Alejandro Sincich
