Hello!
I use TPS7A49 and TPS7A30 to provide bipolar supply. The output voltage is adjusted by the R1-R2 divider (see datasheet, p.11 or 12) and it is noted that current of this divider must be equal to or greater than 5uA. The question is how much could this current be?
For example, I calculated values for Vout=+5V: R1 = 5.1k, R2 = 1.6k. The current in this case I = 746uA. Is it normal for TPS7A49 or can destroy the scheme?
Regards, Alexander Uvarov.
