LP5900 improve PSSR at freqs >1 MHz
Other Parts Discussed in Thread: LP5900
How can I improve LP5900 PSSR at frequencies >1 MHz?  How much does it improve if Vin is increased?  Does a RF output bypass cap help or is an external LPF the only solution?  My application is a microwave band VCO and it's very sensitive to power supply noise.
Eric
  • Hello Eric,
    The bandwidth of the LP5900 limits the PSRR to be effective up to 100kHz regardless of VIN. Beyond 100kHz, your selection of external components will provide the filtering. I would suggest going with a LPF design if you need to filter  past 1MHz.
