could you please tell me what is the minimun value for the pull-up resistors for the PGOOD and LBO pins of TPS61130?
Say Vout_dc/dc=3V3 and Vout_ldo=2V5.
Many thanks for you suppport!
Kind regards,
Winnin_Eleven_8
Kind regards,
Winnin_Eleven_8
The electrical specs table shows that both of those pins were tested sinking 100uA. So, I would not size the resistor to allow more than 3x that value. The problem is that the internal pull down FET has a finite resistance that is not given. If the pull up resistor is too small, the voltage divider between it and the internal pull down FET resistance will result in a voltage that is higher than a standard low voltage. Also, those pull down FETs are not rated for more than a few mAs at the maximum.
