Hello to All
I am using Switching regulator - LM22670-ADJ 3.3V
Power my board Digital and Analog Side.
The for the analog side the 3.3V is filter with ferrite bead 1kOhm@100MHz and decoupling capacitors.
I am measuring some analog sensor - and my ADC got very noisy signal and we cannot work with that signal.
On the scope I saw that I have about 200mV ptp noise in the Vout of the switcher (the prob was with minimum length - avoid antennas, GND surrounding the prob)
When I am zoom in the 200mV I saw a signal ~91MHz (maybe there is more signals but non seen for that stage - my scope Agilent MSO-X2024A 200MHz)
When I test my switching SW pin I found that there is a ringing (rising up & falling down) with that frequency - ~90MHz.
My layout is as minimal as possible - 2 side of the board -- like the EVB - I can post SCH and layout if needed
I saw few TI tutorial - using NP0 C0G capacitors with high SRF and using RC snubber circuit on Vout
http://trainingcenter.ti.com/ti/training/cplayer?2&umfid=a4e91a82-46df-46d2-ab02-3e553f53d3d6
with no Formulas how to find capacitors values
or for snubber circuit
http://www.ti.com/ww/en/analog/power_management/snubber_circuit_design.html
with few unknown that cannot use the Formulas
My problem is how calculate the values on the capacitors or the snubber circuit to filter out the noise freaquency
Could any body give good example for such problem with detailed solution
Your help needed
Mayer
