TPS23753 Startup waveform
Other Parts Discussed in Thread: TPS23753A
2313.SW_StartUp.pdf
Hi
Please teach me about the rise waveform of TPS23753A.
There is 3ms stop switching timing when TPS23753A rise timing.(Pls. see attached file.)
Is this normal operation?
PAN-M
  • The description starts on pg 15 of the datasheet (Startup and Converter Operation). There is a "handoff" between primary Vc and secondary (CTL) towards the end of converter start up. If the output overshoots a bit, CTL will come down quickly as shown in your plot below Vzdc (~1.5V) and switching will stop until Vout droops sufficiently.
    Tuning secondary (error amp) soft start can help with this transition (see pg 18, figure 21 of the DS).
  • Thank you for answer.
    I understood the "handoff".
    PAN-M
