Please let me know two points below about how to use TLC5941.
- Although I think that the data of SCLK updates SID data by the 193rd bit, when this bit does not exist, what happens?
For example)
193 bits is not, and will 1 bit of SCLK of the next GS data transmission be equivalent to 193 bits, and will shift 1 bit?
Or
Is excessive data of 193 bits or more disregarded?
In that case, which shall be disregarded between the first (1 bit~) data and the last (193 bits or more)?
- Is there any method of checking whether Dot Correction data is set correctly?
If there is a method, please let me know.
Thank you for your consideration.
