"DEV_CONFIG 0x32" command in power mgmt IC TPS65310 has some discrepancies
Other Parts Discussed in Thread: TPS65310A-Q1
Hi I have downloaded latest datasheet from TI website for this IC.
Revision information:
TPS65310A-Q1
SLVSC15A –MAY 2013–REVISED JUNE 2013
If you see the page-45, for "DEV_CONFIG 0x32" command there are few discrepancies:
1. 'HS_CLDIS' bit is available in desciption, where as its not present in bit mapping table
2. 'RSV' bit is named twice
3. description of 'RSV:1' and 'RSV:0' has some confusions.
4. 'RSV:0' has a default setting of '0', but description says keep this bit as 1
