TPS7A7100 current sensing
Other Parts Discussed in Thread: TPS7A7100
Hi, I'm looking to use the TPS7A7100 in a new design but I also need current sensing on the output. Is it feasable to place a current sense resistor in the output line and connect the FB pin to the load side of this resistor? The reason is because I want the load to see the full regulated voltage despite the voltage drop (up to 1V) across the resistor.
