Bq27200 gauging with solar panel
Other Parts Discussed in Thread: BQ27200
Hi ,
I am trying to gauge Solar panel output
i need help from you guys on how to gauge it and mimic the Solar panel instead of a battery pack.
I also need suggestions- should i need to Configure the factory settings of BQ27200 EEPROM registers ?
if yes what are the information i need to gather before setting the EEPROM registers ?
Is it mandatory to alter the EEPROM registers??
PFA schematic for detailed description on my connections with BQ27200.
Hoping i get reply from you guys soon we are nearing to production deadline.we have to freeze on the part BQ27200.
  • Hi Rajath,
    What exactly do you want to gauge about the solar panel?
    Do you want to just measure the voltage, current, and temperature?
    A fuel gauge like the bq27200 is running an algorithm to tell you how much usable battery capacity is available in a battery, so I'm not sure why you want to use it with a solar panel that does not store any energy.
  • Hi dMax,
       Our application is based on solar power harvesting so we need to calculate the charge.
    We need to measure voltage ,current and temperature also.
    So to calculate these values can i directly read the registers in BQ27200 and get the required info or should i need to configure the EEPROM registers as told by one of your TI employee in one of the forums.if yes then-
     What are the information i need to gather before setting the EEPROM registers ?
    It would be grateful if you could help us out by giving clear information on how to use BQ27200 IC for our application.
    Ref link
    http://e2e.ti.com/support/power_management/battery_management/f/180/t/192772.aspx
    Here TI employee tells customer need to program the EEPROM reg to get a valid values when u read the BQ27200 registers.
