I am using bq500210 and bq51013A for a battery charging solution.
I have a 42.2kOhm between ground and pin 44 (LED_MODE). According to the table in the datasheet of bq500210 this corresponds to Generic+CS100+Cs909+CS6min mode. After I pull TS pin to high, I see a solid green led for 5 mins and power transfer stops. After that power transfer starts again but the led is now turned off completely. I would like the led to indicate solid green to keep indicating end of charging .
In the data sheet of bq500210 it says
This is what I want to achieve. But it looks like puling TS_CTRL pin to high does not transmit a CS100 message but an EPT message. How can I transmit a CS100 message?
Any inputs in this regards will be very helpful to me. Thanks in advance.
Sean
