How to modify the value in the registers in the BQ34Z100
Other Parts Discussed in Thread: BQ34Z100
(1)I'm using I2C to communicate with the BQ34Z100,but When I try to modify the value in the registers ? such as "DesignCapacity" ……
(2)how to modify the value in the Data Flash,for example, the "Design Capacity" is in the class "Configuration",and it's subclassID is 48 with offset 21,how can I use these parameters to read and modify the value? I hope someone can tell me step by step ……
thanks
  • Moore,
    The DesignCapacity can be changed in the data flash through the procedure shown on page 11 of the Going to Production With the bq34z1xx report. (SLUA665) The report uses the Serial Number as an example, but updating the DesignCapacity will be the same process. Note that data is transferred in and out of the DF in 32 byte blocks. You will need to update the data that you want to change within the block.
    Tom
