I have a question about parameter minimum battery capacity for BQ34Z950 and BQ20z95.
In the Products tab in Power Management/Battery Fuel (Gas) Gauge Products at ti.com:
http://www.ti.com/lsds/ti/power-management/battery-fuel-gauge-products.page
there is a table to select parts. In the header of this table there is a parameter called 'Battery Capacity (Min) (mAh)'.
For parts BQ34Z950 and BQ20z95 that parameter is 800 mAh in the table but the datasheets of the parts do not mention anything of the sort. Do these parts really have this restriction?
I need to use a fuel gauge and AFE solution for a multiple cell series array in which each cell has a capacity smaller than 800 mAh but all of them together have a greater capacity than 800 mAh. Specifically each battery has a capacity of 300 mAh. Can I use parts BQ34Z950 and BQ20z95 in this case?
Alberto
