Detecting when RX is on a charge pad
Other Parts Discussed in Thread: BQ51050B
Is there a simple way to detect when the RX (bq51050b) is on a charge pad. Currently I'm using the CHG pin to tell the device when the battery is charging, but there is some desire to have this signal indicate when the device is on the charge pad regardless of charge state.
I thought I might be able to use the AD_EN pin but unfortunately that has the reverse operation than I thought it had (disables the wireless when wired is active instead of disabling wired when wireless is active).
Thoughts?
