Probably an Easy Question about the FusionFirmwareDownload command Line Program (and the UCD9090)
Other Parts Discussed in Thread: UCD9090
I'm hoping this is pretty easy.  I was trying to solve this a much harder way, but I think this should work much better.
I want to use the FusionFirmwareDownload command line program to download my hex file to the UCD9090.  But I can't get the options right (and I don't really know what I'm doing yet!)
This  is the latest command I tried:
FusionFirmwareDownload --address 101 --pflash download --pflash-checksum calc --dflash erase -–infile UCD9090.hex --execute-program --rescan
where UCD9090.hex is my hex file (generated by the GUI)
but all I get are error messages... :
No program flash data was found in your input, etc...
So ... I'm assuming that means my hex file is not right.  But I can't figure out how to generate the right file.  Any ideas?  Thanks a lot.
-Matt
  • Anybody have any idea?
  • Sorry for the delay.
    This is a common issue, the UCD90xxx sequencers come preloaded with FW, end user just needs to apply their configuration to the device, this is a different command line tool.
    If you are using the FW command lline tool then I suspect you are familar with the Configuration Programming for UCD Devices document.  If not it can be located through the Fusion Digital Power Designer GUI under Help --> Documentation & Help Center.  Below is the section that covers installing configuration with command line.
