LM5010AVAL
Guru 13485 points
wish to change half of the EVAL’s to 12V output voltage instead of 5V.
Should I change R1 and R2 only? (Current limit of ~1A will be fine with me).
  • Yes. Also please check the rating of output capacitors. Please note that the frequency is proportional to the output voltage so I would suggest changing the RON resistor proportional to VOUT to keep the frequency unchanged.
