TPS65910 HOT DIE interrupt
Other Parts Discussed in Thread: TPS65910
Hi!
I am using a design that a MCU controls TPS65910 and communicates with SITARA with SPI.
So, its not the MPU that receives PMIC interrupt information..
And im testing HOT_DIE interrupt and got a problem..
When i receive this interrupt, i clear the status register and then turn off the TPS65910..
But 10 seconds later, when i turn it on again, the HOT DIE interrupt activates again! So, i do the same thing, and this second time everything becomes normal.. the PMIC goes on..
And, if i dont clear the interrupt the first time.. everytime i turn on TPS65910 it activates HOT DIE again and keep turning off.. infinite cycle..
So.. whenever i turn it off and then on.. it should reset all registers write? Why is this happening?
Daniel.
