If designing with the bq34z100 for only a 1s application, what should be done with the VEN pin?
Should it be tied high / low / floating?
Can you share how large this impedance is? Can I leave this pin unconnected if I’m not using an external voltage divider and not worry about it floating to 2.5V (for example during an EMI event), or should I tie it to VSS, and if so, how strong does my pull-down need to be?
Thank you, Keith
