When I do not use SYNC pin, is it correct that this pin is open?
Daisuke
Daisuke
External input to the SYNC pin is recommended as open drain, since pulling the pin low terminates the current cycle. The internal oscillator has a weak pull-up so it is ok to leave SYNC unconnected if not used
Daisuke,
That is correct. When the SYNC pin is not used it can be left open.
Garrett Roecker
