hi, i want to design a circuit with bq24650 and a lead-acid battery, but i saw the design example in this application note http://www.ti.com/lit/pdf/SLVA437, i checked this, and i not understand this.
if the result of RT is 887 k in the desig you put 947k and if R23 the result is 100k you have 10k and you put the 25k in this resistor?
