I'm in the final design stages for a USB charger product that uses your TPS2513 DCP Controller. I just discovered that you now have an "A" version of this part that provides a Divider 3 output to support Apple's 12-watt charging scheme. I would like to use the TPS2513A instead of the TPS2513, but I can't find a distributor with stock. Can you tell me when your distributors will have this part, or if it can be ordered directly from TI (and lead time)?
I'll need ~250 for an initial low-rate production run.
Thanks.
