I'm trying to set the fault index for the fault FIFO using the EBh command (1st byte) but I'm always getting the 1st fault. Is there a different way to set the fault index?
(I see on the 2nd byte of the return value for the EBh command, that the total number of logged faults detail is larger than 1, The ECh command returns always the 1st fault entry only).
Thank you in advance,
Meir
