What would be lowest cost solution to derive +12Vdc / 600mA and +5Vdc / 1A from a 20.5-26.5V AC source?
Thanks!
Thanks!
Hello Jeetendra,
The easiest way for you to find the lowest cost solution for your design would be to place a full wave rectifier and filtering cap to create DC rail. You then take the resulting DC value, which depends on whether the voltage you gave in your post is the peak or RMS voltage, and use that DC value as the input to WEBENCH Power Architect and then selecting the proper loads at +12 and +5 and tuning the dial to the lowest BOM cost option.
http://www.ti.com/lsds/ti/analog/webench/power-architect.page
Ryan May
Hello Jeentendra,
One of the options in the power architect is to define a rail as an LDO. Look right below the load voltage an LDO supply can be selected as the desired rail supply.
Ryan May
