BQ34Z100 SOC and remaining capacity goes to ZERO
My fuel gauge PCBA is working properly, 2-in-series LiFePo4, HDQ communication port and 4 LEDs.
The cells were fully charged, once I try to discharge it, the SOC goes to 0, and the remaining capacity goes to 0 also. My discharge current is about 6.5A. When I reduce the discharge current to about 1 ~ 2A, the reading seems to be OK.
What have I done wrong? or what can I do to not let it reset.
The .GG file is attached, please rename the extension to .GG to try.
[Header]
bq EVSW Version = 0.9.90
DeviceName = bq34z100HDQ v0.06
Time = 24/11/2013 9:57:26 PM
[Safety(Configuration)]
OT Chg = 55.0
OT Chg Time = 2
OT Chg Recovery = 50.0
OT Dsg = 60.0
OT Dsg Time = 2
OT Dsg Recovery = 55.0
[Charge Inhibit Cfg(Configuration)]
Chg Inhibit Temp Low = 0.0
Chg Inhibit Temp High = 45.0
Temp Hys = 5.0
[Charge(Configuration)]
Suspend Low Temp = -5.0
Suspend High Temp = 55.0
[Charge Termination(Configuration)]
Taper Current = 100
Min Taper Capacity = 25
Cell Taper Voltage = 100
Current Taper Window = 40
TCA Set % = 99
TCA Clear % = 95
FC Set % = 100
FC Clear % = 98
DODatEOC Delta T = 10.0
[Data(Configuration)]
Rem Cap Alarm = 100
Initial Standby = -10
Initial MaxLoad = -500
Manuf Date = 20-Nov-2013
Ser. Num. = 0001
Cycle Count = 19
CC Threshold = 1000
Design Capacity = 3000
Design Energy = 21900
SOH Load I = -400
TDD SOH Percent = 90
Cell Charge Voltage T1-T2 = 3650
Cell Charge Voltage T2-T3 = 3650
Cell Charge Voltage T3-T4 = 3650
Charge Current T1-T2 = 10
Charge Current T2-T3 = 50
Charge Current T3-T4 = 30
JEITA T1 = 0
JEITA T2 = 10
JEITA T3 = 45
JEITA T4 = 55
ISD Current = 10
ISD I Filter = 127
Min ISD Time = 7
Design Energy Scale = 1
Device Name = Cauldron
Manufacturer Name = Texas Inst.
Device Chemistry = LIPO
[Discharge(Configuration)]
SOC1 Set Threshold = 150
SOC1 Clear Threshold = 175
SOCF Set Threshold = 75
SOCF Clear Threshold = 100
Cell BL Set Volt Threshold = 2800
Cell BL Set Volt Time = 2
Cell BL Clear Volt Threshold = 2900
Cell BH Set Volt Threshold = 4300
Cell BH Volt Time = 2
Cell BH Clear Volt Threshold = 3700
[Manufacturer Data(Configuration)]
Pack Lot Code = 0000
PCB Lot Code = 0000
Firmware Version = 0000
Hardware Revision = 0000
Cell Revision = 0000
DF Config Version = 0000
[Integrity Data(Configuration)]
Static Chem DF Checksum = 6B64
[Lifetime Data(Configuration)]
Lifetime Max Temp = 30.0
Lifetime Min Temp = 20.0
Lifetime Max Chg Current = 0
Lifetime Max Dsg Current = 0
Lifetime Max Pack Voltage = 3200
Lifetime Min Pack Voltage = 3500
[Lifetime Temp Samples(Configuration)]
LT Flash Cnt = 0
[Registers(Configuration)]
Pack Configuration = 0961
Pack Configuration B = FF
Pack Configuration C = 30
LED_Comm Configuration = 02
Alert Configuration = 0000
Number of series cell = 2
[Lifetime Resolution(Configuration)]
LT Temp Res = 1.0
LT Cur Res = 100
LT V Res = 25
LT Update Time = 60
[LED Display(Configuration)]
LED Hold Time = 5
[Power(Configuration)]
Flash Update OK Cell Volt = 2800
Sleep Current = 10
FS Wait = 0
[Manufacturer Info(System Data)]
Block A 0 = 00
Block A 1 = 00
Block A 2 = 00
Block A 3 = 00
Block A 4 = 00
Block A 5 = 00
Block A 6 = 00
Block A 7 = 00
Block A 8 = 00
Block A 9 = 00
Block A 10 = 00
Block A 11 = 00
Block A 12 = 00
Block A 13 = 00
Block A 14 = 00
Block A 15 = 00
Block A 16 = 00
Block A 17 = 00
Block A 18 = 00
Block A 19 = 00
Block A 20 = 00
Block A 21 = 00
Block A 22 = 00
Block A 23 = 00
Block A 24 = 00
Block A 25 = 00
Block A 26 = 00
Block A 27 = 00
Block A 28 = 00
Block A 29 = 00
Block A 30 = 00
Block A 31 = 00
[IT Cfg(Gas Gauging)]
Load Select = 1
Load Mode = 0
Max Res Factor = 15
Min Res Factor = 3
Ra Filter = 500
Fast Qmax Start DOD % = 92
Fast Qmax End DOD % = 96
Fast Qmax Start Volt Delta = 200
Cell Terminate Voltage = 3000
Cell Term V Delta = 50
ResRelax Time = 200
User Rate-mA = 0
User Rate-Pwr = 0
Reserve Cap-mAh = 0
Reserve Energy = 0
Max Scale Back Grid = 4
Cell Max DeltaV = 200
Cell Min DeltaV = 0
Max Sim Rate = 2
Min Sim Rate = 20
Ra Max Delta = 44
Qmax Max Delta % = 5
Cell DeltaV Max Delta = 10
Fast Scale Start SOC = 10
Charge Hys V Shift = 40
[Current Thresholds(Gas Gauging)]
Dsg Current Threshold = 60
Chg Current Threshold = 75
Quit Current = 40
Dsg Relax Time = 60
Chg Relax Time = 60
Quit Relax Time = 1
Cell Max IR Correct = 400
[State(Gas Gauging)]
Qmax Cell 0 = 3000
Cycle Count = 0
Update Status = 00
Cell V at Chg Term = 3630
Avg I Last Run = -299
Avg P Last Run = -1131
Cell Delta Voltage = 2
T Rise = 20
T Time Constant = 1000
[OCVa Table(OCV Table)]
Chem ID = 0417
[R_a0(Ra Table)]
Cell0 R_a flag = FF55
Cell0 R_a 0 = 43
Cell0 R_a 1 = 52
Cell0 R_a 2 = 51
Cell0 R_a 3 = 48
Cell0 R_a 4 = 50
Cell0 R_a 5 = 58
Cell0 R_a 6 = 54
Cell0 R_a 7 = 111
Cell0 R_a 8 = 109
Cell0 R_a 9 = 118
Cell0 R_a 10 = 117
Cell0 R_a 11 = 132
Cell0 R_a 12 = 142
Cell0 R_a 13 = 198
Cell0 R_a 14 = 333
[R_a0x(Ra Table)]
xCell0 R_a flag = FFFF
xCell0 R_a 0 = 43
xCell0 R_a 1 = 52
xCell0 R_a 2 = 51
xCell0 R_a 3 = 48
xCell0 R_a 4 = 50
xCell0 R_a 5 = 58
xCell0 R_a 6 = 54
xCell0 R_a 7 = 111
xCell0 R_a 8 = 109
xCell0 R_a 9 = 118
xCell0 R_a 10 = 117
xCell0 R_a 11 = 132
xCell0 R_a 12 = 142
xCell0 R_a 13 = 198
xCell0 R_a 14 = 333
[Data(Calibration)]
CC Gain = 9.7
CC Delta = 9.682
CC Offset = -0.66
Board Offset = -0.33
Int Temp Offset = 0.0
Ext Temp Offset = -.5
Voltage Divider = 19158
[Current(Calibration)]
Deadband = 5
[Codes(Security)]
Sealed to Unsealed = 36720414
Unsealed to Full = FFFFFFFF
Authen Key3 = 01234567
Authen Key2 = 89ABCDEF
Authen Key1 = FEDCBA98
Authen Key0 = 76543210
  • Liat,
    You Cell Term Voltage is set to 3000mV, which may be too high for LiFePO4 cells. The cell voltages may be dropping below the Cell Term Voltage under the high discharge current and RM will get set to zero. It also does not look like you have run an optimization cycle. This is important to fine tune Qmax and the Ra-table. You should also set the Max Sim Rate to 0 to allow the simulation to perform properly at a high C rate. I will review the log data, if you can attach it.
    Tom
  • hi Tom,
    thanks for the advice.
    1) after the adjusting the CellTermVoltage to 2500mA , the SOC does not reset  !!! amazing. I also set the MaxSimRate to 0. I am using LiFePO4, and the cut off voltage should be 2V, but this software will not let me go below 2.5V... is there something I can do here ?
    2) I have attached the new .GG file here ( please rename .TXT to .GG )
    3) I also attached the latest discharge follow by charging cycle log here... they looks very normal now.
    4) If you spot something wrong with the GG file, please let me know again.
    thanks again,
    Billy
    [Header]
    Time = 26/11/2013 1:35:46 PM
    OT Chg = 55.0
    OT Chg Time = 2
    OT Dsg = 60.0
    OT Dsg Time = 2
    Temp Hys = 5.0
    Taper Current = 100
    TCA Set % = 99
    TCA Clear % = 95
    FC Set % = 100
    FC Clear % = 98
    Rem Cap Alarm = 100
    Initial MaxLoad = -10000
    Ser. Num. = 0001
    Cycle Count = 19
    CC Threshold = 1000
    SOH Load I = -400
    JEITA T1 = 0
    JEITA T2 = 10
    JEITA T3 = 45
    JEITA T4 = 55
    ISD Current = 10
    ISD I Filter = 127
    Min ISD Time = 7
    PCB Lot Code = 0000
    LT Flash Cnt = 0
    LT Temp Res = 1.0
    LT Cur Res = 100
    LT V Res = 25
    LT Update Time = 60
    LED Hold Time = 5
    Sleep Current = 10
    FS Wait = 0
    Block A 0 = 00
    Block A 1 = 00
    Block A 2 = 00
    Block A 3 = 00
    Block A 4 = 00
    Block A 5 = 00
    Block A 6 = 00
    Block A 7 = 00
    Block A 8 = 00
    Block A 9 = 00
    Block A 10 = 00
    Block A 11 = 00
    Block A 12 = 00
    Block A 13 = 00
    Block A 14 = 00
    Block A 15 = 00
    Block A 16 = 00
    Block A 17 = 00
    Block A 18 = 00
    Block A 19 = 00
    Block A 20 = 00
    Block A 21 = 00
    Block A 22 = 00
    Block A 23 = 00
    Block A 24 = 00
    Block A 25 = 00
    Block A 26 = 00
    Block A 27 = 00
    Block A 28 = 00
    Block A 29 = 00
    Block A 30 = 00
    Block A 31 = 00
    Load Select = 1
    Load Mode = 0
    Max Res Factor = 15
    Min Res Factor = 3
    Ra Filter = 500
    Cell Terminate Voltage = 2500
    ResRelax Time = 200
    User Rate-mA = 0
    User Rate-Pwr = 0
    Reserve Cap-mAh = 0
    Reserve Energy = 0
    Cell Min DeltaV = 0
    Max Sim Rate = 0
    Min Sim Rate = 20
    Ra Max Delta = 44
    Quit Current = 40
    Dsg Relax Time = 60
    Chg Relax Time = 60
    Quit Relax Time = 1
    Qmax Cell 0 = 3000
    Cycle Count = 0
    Update Status = 00
    T Rise = 20
    Chem ID = 0417
    [R_a0(Ra Table)]
    Cell0 R_a 0 = 43
    Cell0 R_a 1 = 52
    Cell0 R_a 2 = 51
    Cell0 R_a 3 = 48
    Cell0 R_a 4 = 50
    Cell0 R_a 5 = 58
    Cell0 R_a 6 = 54
    Cell0 R_a 7 = 111
    Cell0 R_a 8 = 109
    Cell0 R_a 9 = 118
    Cell0 R_a 10 = 117
    Cell0 R_a 11 = 132
    Cell0 R_a 12 = 142
    Cell0 R_a 13 = 198
    Cell0 R_a 14 = 333
    [R_a0x(Ra Table)]
    xCell0 R_a 0 = 43
    xCell0 R_a 1 = 52
    xCell0 R_a 2 = 51
    xCell0 R_a 3 = 48
    xCell0 R_a 4 = 50
    xCell0 R_a 5 = 58
    xCell0 R_a 6 = 54
    xCell0 R_a 7 = 111
    xCell0 R_a 8 = 109
    xCell0 R_a 9 = 118
    xCell0 R_a 10 = 117
    xCell0 R_a 11 = 132
    xCell0 R_a 12 = 142
    xCell0 R_a 13 = 198
    xCell0 R_a 14 = 333
    [Data(Calibration)]
    CC Gain = 9.7
    CC Delta = 9.682
    CC Offset = -0.66
    Deadband = 5
    [Codes(Security)]
    bq EVSW Version: 0.9.90 for bq34z100HDQ v0.06
    Device:100,Ver:0.06
    26/11/2013 9:56:56 AM
    Sample	Stamp	~Elapsed(s)	Control	CtrlStatus	StateofCharge	RemCap	FullChgCap	Voltage	AveCur	Temperature	Flags	@Rate(@)	@TimeEmpty	NomAvailCap	FullAvailCap	AvgTimeEmpty	AvgTimeFull	StandbyCurr	StandTTE	MaxLoadCurrent	MaxTTE	AvailEnergy	AvailPower	TTEConstPwr	IntTemp	CycleCnt	StateofHealth	Charge Voltage	Charge Current	Passed Charge	DOD0	SelfDischargeCurrent	PackConfig	Current
    1	9:57:08 AM	0	6014	6014	95	2788	2960	6172	-7	32.4	0100	0	65535	2798	2970	23897	65535	-10	16788	-10000	17	9018	0	65535	32.9	19	99	7300	1500	39	728	0	0961	0
    2	9:57:20 AM	12	6014	6014	95	2788	2960	6172	-1	31.3	0100	0	65535	2798	2970	65535	65535	-10	16788	-10000	17	9018	0	65535	32.0	19	99	7300	1500	39	728	0	0961	0
    3	9:57:32 AM	24	6014	6004	95	2788	2960	6172	0	31.3	0100	0	65535	2798	2970	65535	65535	-10	16788	-10000	17	9012	51681	39	31.8	19	99	7300	1500	40	728	0	0961	-5097
    4	9:57:44 AM	36	6004	6004	94	2771	2961	5438	-3000	32.6	1101	0	65535	2781	2971	55	65535	-10	16686	-10000	17	8963	51764	39	33.7	19	99	7300	1500	58	728	0	0961	-5069
    5	9:57:56 AM	48	6004	6004	94	2754	2961	5426	-4160	36.7	1101	0	65535	2763	2971	39	65535	-10	16578	-10000	17	8917	51800	39	37.5	19	99	7300	1500	77	728	0	0961	-5063
    6	9:58:08 AM	60	6004	6004	93	2736	2816	5418	-4693	41.0	1101	0	65535	2746	2971	35	65535	-10	16470	-10000	16	7796	51823	34	40.7	19	99	7300	1500	93	728	0	0961	-5062
    7	9:58:20 AM	72	6004	6004	92	2574	2816	5418	-4911	44.5	1101	0	65535	2728	2971	31	65535	-10	16368	-10000	15	7750	51826	34	43.2	19	99	7300	1500	112	728	0	0961	-5061
    8	9:58:32 AM	84	6004	6004	91	2556	2816	5412	-4996	47.6	1801	0	65535	2709	2971	31	65535	-10	16254	-10000	15	7699	51838	34	45.9	19	99	7300	900	130	728	0	0961	-5062
    9	9:58:45 AM	97	6004	6004	91	2538	2816	5412	-5035	50.4	1801	0	65535	2693	2971	30	65535	-10	16146	-10000	15	7650	51838	34	48.0	19	99	7300	900	147	728	0	0961	-5062
    10	9:58:57 AM	109	6004	6004	90	2518	2813	5412	-5051	52.9	1801	0	65535	2674	2971	30	65535	-10	16044	-10000	15	7615	51836	33	49.8	19	99	7300	900	165	728	0	0961	-5063
    11	9:59:09 AM	121	6004	6004	89	2499	2813	5412	-5058	54.9	1801	0	65535	2656	2971	30	65535	-10	15936	-10000	15	7566	51836	33	51.5	19	99	7300	0	183	728	0	0961	-5063
    12	9:59:21 AM	133	6004	6004	89	2481	2813	5410	-5061	56.8	1801	0	65535	2639	2971	29	65535	-10	15834	-10000	15	7520	51838	33	53.2	19	99	0	0	200	728	0	0961	-5064
    13	9:59:33 AM	145	6004	6004	88	2464	2813	5410	-5063	58.4	1801	0	65535	2621	2971	29	65535	-10	15726	-10000	15	7473	51838	33	54.4	19	99	0	0	219	728	0	0961	-5064
    14	9:59:45 AM	157	6004	6004	88	2551	2918	5410	-5064	59.7	1801	0	65535	2608	2975	30	65535	-10	15642	-10000	15	8090	51838	35	55.4	19	99	0	0	235	728	0	0961	-5065
    15	9:59:57 AM	169	6004	6004	87	2534	2918	5410	-5064	60.9	5801	0	65535	2590	2975	30	65535	-10	15540	-10000	15	8044	51835	35	56.3	19	99	0	0	254	728	0	0961	-5065
    16	10:00:09 AM	181	6004	6004	87	2474	2876	5410	-5064	62.0	5801	0	65535	2570	2974	29	65535	-10	15420	-10000	15	7701	51835	34	57.3	19	99	0	0	272	728	0	0961	-5065
    17	10:00:21 AM	193	6004	6004	86	2455	2876	5410	-5065	63.2	5801	0	65535	2553	2974	29	65535	-10	15312	-10000	15	7652	51835	34	58.2	19	99	0	0	289	728	0	0961	-5065
    18	10:00:33 AM	205	6004	6004	85	2439	2876	5408	-5065	64.2	5801	0	65535	2536	2975	28	65535	-10	15216	-10000	14	7239	51827	32	59.1	19	99	0	0	307	728	0	0961	-5066
    19	10:00:45 AM	217	6004	6004	85	2439	2876	5408	-5065	64.2	5801	0	65535	2536	2975	28	65535	-10	15216	-10000	14	7239	51827	32	59.1	19	99	0	0	307	728	0	0961	-5066
    20	10:00:57 AM	229	6004	6004	84	2368	2824	5408	-5066	65.2	5801	0	65535	2519	2975	28	65535	-10	15108	-10000	14	7190	51835	31	59.7	19	99	0	0	324	728	0	0961	-5067
    21	10:01:09 AM	241	6004	6004	84	2350	2824	5408	-5066	65.8	5801	0	65535	2501	2975	28	65535	-10	15006	-10000	14	7144	51838	31	60.4	19	99	0	0	342	728	0	0961	-5066
    22	10:01:21 AM	253	6004	6004	82	2141	2632	5408	-5066	66.5	5801	0	65535	2482	2974	25	65535	-10	14892	-10000	13	6351	51838	28	60.9	19	99	0	0	361	728	0	0961	-5066
    23	10:01:33 AM	265	6004	6004	81	2123	2632	5408	-5067	66.9	5801	0	65535	2465	2974	25	65535	-10	14790	-10000	13	6299	51838	28	61.4	19	99	0	0	378	728	0	0961	-5067
    24	10:01:45 AM	277	6004	6004	77	1743	2269	5408	-5067	67.5	5801	0	65535	2447	2974	21	65535	-10	14682	-10000	10	5118	51835	22	61.8	19	99	0	0	396	728	0	0961	-5067
    25	10:01:57 AM	289	6004	6004	77	1725	2269	5408	-5067	68.0	5801	0	65535	2430	2974	20	65535	-10	14568	-10000	10	5066	51835	22	62.4	19	99	0	0	413	728	0	0961	-5067
    26	10:02:09 AM	301	6004	6004	76	1708	2269	5408	-5067	68.4	5801	0	65535	2411	2974	20	65535	-10	14466	-10000	10	5021	51832	22	62.6	19	99	0	0	431	728	0	0961	-5068
    27	10:02:21 AM	313	6004	6004	73	1559	2139	5408	-5067	68.6	5801	0	65535	2393	2974	18	65535	-10	14358	-10000	9	4469	51832	20	62.8	19	99	0	0	449	728	0	0961	-5068
    28	10:02:33 AM	325	6004	6004	73	1541	2139	5408	-5068	68.9	5801	0	65535	2376	2974	18	65535	-10	14250	-10000	9	4420	51829	19	62.7	19	99	0	0	466	728	0	0961	-5069
    29	10:02:45 AM	337	6004	6004	71	1437	2052	5408	-5068	69.0	5801	0	65535	2358	2974	17	65535	-10	14148	-10000	9	4000	51835	18	63.3	19	99	0	0	485	728	0	0961	-5067
    30	10:02:57 AM	349	6004	6004	70	1419	2052	5402	-5068	69.4	5801	0	65535	2341	2974	17	65535	-10	14040	-10000	9	3952	51837	17	63.5	19	99	0	0	501	728	0	0961	-5067
    31	10:03:09 AM	361	6004	6004	66	1233	1883	5402	-5068	69.8	5801	0	65535	2323	2974	15	65535	-10	13938	-10000	7	3355	51837	15	63.8	19	99	0	0	520	728	0	0961	-5068
    32	10:03:21 AM	373	6004	6004	65	1215	1883	5402	-5068	70.0	5801	0	65535	2304	2974	14	65535	-10	13824	-10000	7	3303	51847	14	64.0	19	99	0	0	538	728	0	0961	-5068
    33	10:03:33 AM	385	6004	6004	64	1196	1883	5402	-5068	70.1	5801	0	65535	2287	2974	14	65535	-10	13716	-10000	7	3255	51847	14	64.0	19	99	0	0	555	728	0	0961	-5068
    34	10:03:45 AM	397	6004	6004	59	1008	1711	5402	-5069	70.4	5801	0	65535	2270	2975	12	65535	-10	13620	-10000	6	2717	51845	12	64.0	19	99	0	0	573	728	0	0961	-5069
    35	10:03:57 AM	409	6004	6004	58	989	1711	5402	-5068	70.3	5801	0	65535	2253	2975	12	65535	-10	13512	-10000	6	2668	51847	12	64.3	19	99	0	0	590	728	0	0961	-5068
    36	10:04:09 AM	421	6004	6004	58	989	1711	5402	-5068	70.3	5801	0	65535	2253	2975	12	65535	-10	13512	-10000	6	2668	51847	12	64.3	19	99	0	0	590	728	0	0961	-5068
    37	10:04:21 AM	433	6004	6004	54	843	1583	5402	-5068	70.7	5801	0	65535	2235	2975	10	65535	-10	13404	-10000	5	2263	51847	10	64.6	19	99	0	0	610	728	0	0961	-5068
    38	10:04:33 AM	445	6004	6004	52	823	1583	5402	-5068	70.8	5801	0	65535	2215	2975	10	65535	-10	13284	-10000	5	2208	51847	10	64.7	19	99	0	0	630	728	0	0961	-5068
    39	10:04:45 AM	457	6004	6004	50	771	1549	5398	-5068	71.0	5801	0	65535	2196	2975	9	65535	-10	13164	-10000	5	2048	51845	9	64.7	19	99	0	0	649	728	0	0961	-5069
    40	10:04:57 AM	469	6004	6004	49	751	1549	5398	-5069	71.1	5801	0	65535	2177	2975	9	65535	-10	13056	-10000	5	2000	51855	9	64.8	19	99	0	0	666	728	0	0961	-5069
    41	10:05:09 AM	481	6004	6004	47	711	1527	5398	-5069	71.3	5801	0	65535	2158	2974	8	65535	-10	12948	-10000	4	1899	51857	8	65.0	19	99	0	0	684	728	0	0961	-5068
    42	10:05:21 AM	493	6004	6004	47	714	1547	5398	-5069	71.1	5801	0	65535	2141	2975	8	65535	-10	12846	-10000	4	1897	51855	8	64.4	19	99	0	0	703	728	0	0961	-5069
    43	10:05:33 AM	505	6004	6004	45	696	1547	5394	-5069	71.0	5801	0	65535	2124	2975	8	65535	-10	12732	-10000	4	1846	51865	8	64.8	19	99	0	0	720	728	0	0961	-5068
    44	10:05:45 AM	517	6004	6004	44	679	1547	5398	-5069	70.9	5801	0	65535	2105	2975	8	65535	-10	12630	-10000	4	1800	51857	8	64.8	19	99	0	0	738	728	0	0961	-5069
    45	10:05:57 AM	529	6004	6004	43	661	1547	5394	-5068	71.1	5801	0	65535	2089	2975	8	65535	-10	12522	-10000	4	1752	51868	8	64.8	19	99	0	0	755	728	0	0961	-5068
    46	10:06:09 AM	541	6004	6004	42	642	1547	5394	-5068	71.2	5801	0	65535	2070	2975	8	65535	-10	12420	-10000	4	1703	51868	7	65.0	19	99	0	0	773	728	0	0961	-5068
    47	10:06:21 AM	553	6004	6004	41	625	1547	5394	-5068	71.4	5801	0	65535	2052	2975	7	65535	-10	12312	-10000	4	1657	51865	7	65.0	19	99	0	0	791	728	0	0961	-5068
    48	10:06:33 AM	565	6004	6004	40	607	1547	5394	-5068	71.7	5801	0	65535	2035	2975	7	65535	-10	12204	-10000	4	1609	51865	7	65.4	19	99	0	0	808	728	0	0961	-5068
    49	10:06:45 AM	577	6004	6004	39	589	1547	5394	-5069	72.0	5801	0	65535	2017	2975	7	65535	-10	12102	-10000	4	1558	51868	7	65.6	19	99	0	0	827	728	0	0961	-5068
    50	10:06:57 AM	589	6004	6004	37	572	1547	5390	-5069	72.1	5801	0	65535	1998	2975	7	65535	-10	11988	-10000	3	1512	51875	7	65.8	19	99	0	0	845	728	0	0961	-5069
    51	10:07:09 AM	601	6004	6004	36	554	1547	5390	-5069	72.3	5801	0	65535	1982	2975	7	65535	-10	11880	-10000	3	1463	51875	6	65.8	19	99	0	0	862	728	0	0961	-5069
    52	10:07:21 AM	613	6004	6004	36	554	1547	5390	-5069	72.3	5801	0	65535	1982	2975	7	65535	-10	11880	-10000	3	1463	51875	6	65.8	19	99	0	0	862	728	0	0961	-5069
    53	10:07:33 AM	625	6004	6004	35	537	1547	5390	-5069	72.4	5801	0	65535	1963	2975	6	65535	-10	11778	-10000	3	1417	51875	6	65.9	19	99	0	0	880	728	0	0961	-5069
    54	10:07:45 AM	637	6004	6004	34	518	1547	5390	-5069	72.5	5801	0	65535	1945	2975	6	65535	-10	11670	-10000	3	1369	51872	6	66.1	19	99	0	0	899	728	0	0961	-5070
    55	10:07:57 AM	649	6004	6004	33	500	1547	5390	-5070	72.9	5801	0	65535	1928	2975	6	65535	-10	11562	-10000	3	1320	51872	6	66.3	19	99	0	0	915	728	0	0961	-5070
    56	10:08:09 AM	661	6004	6004	32	483	1547	5390	-5070	73.0	5801	0	65535	1910	2975	6	65535	-10	11460	-10000	3	1275	51872	6	66.3	19	99	0	0	934	728	0	0961	-5069
    57	10:08:21 AM	673	6004	6004	31	465	1547	5386	-5070	73.1	5801	0	65535	1891	2975	5	65535	-10	11346	-10000	3	1223	51880	5	66.3	19	99	0	0	951	728	0	0961	-5071
    58	10:08:33 AM	685	6004	6004	29	446	1547	5386	-5070	73.3	5801	0	65535	1874	2975	5	65535	-10	11244	-10000	3	1175	51880	5	66.5	19	99	0	0	969	728	0	0961	-5071
    59	10:08:45 AM	697	6004	6004	28	430	1547	5386	-5071	73.4	5801	0	65535	1856	2975	5	65535	-10	11136	-10000	3	1129	51882	5	66.8	19	99	0	0	987	728	0	0961	-5070
    60	10:08:57 AM	709	6004	6004	27	411	1547	5386	-5070	73.5	5801	0	65535	1839	2975	5	65535	-10	11028	-10000	2	1081	51885	5	66.8	20	99	0	0	1004	728	0	0961	-5071
    61	10:09:09 AM	721	6004	6004	26	394	1547	5384	-5071	73.6	5801	0	65535	1821	2975	5	65535	-10	10926	-10000	2	1035	51885	5	66.6	20	99	0	0	1022	728	0	0961	-5071
    62	10:09:21 AM	733	6004	6004	25	376	1547	5384	-5071	73.4	5801	0	65535	1803	2975	4	65535	-10	10818	-10000	2	986	51885	4	66.8	20	99	0	0	1041	728	0	0961	-5070
    63	10:09:33 AM	745	6004	6004	24	358	1547	5384	-5070	73.5	5801	0	65535	1786	2975	4	65535	-10	10704	-10000	2	935	51885	4	66.7	20	99	0	0	1058	728	0	0961	-5071
    64	10:09:45 AM	757	6004	6004	23	341	1547	5384	-5071	73.7	5801	0	65535	1767	2975	4	65535	-10	10602	-10000	2	890	51885	4	66.9	20	99	0	0	1076	728	0	0961	-5071
    65	10:09:57 AM	769	6004	6004	21	323	1547	5380	-5071	73.9	5801	0	65535	1751	2975	4	65535	-10	10494	-10000	2	841	51885	4	67.0	20	99	0	0	1093	728	0	0961	-5071
    66	10:10:09 AM	781	6004	6004	20	304	1547	5378	-5071	74.1	5801	0	65535	1732	2975	4	65535	-10	10392	-10000	2	793	51895	3	67.4	20	99	0	0	1111	728	0	0961	-5071
    67	10:10:21 AM	793	6004	6004	19	287	1547	5378	-5071	74.3	5801	0	65535	1714	2975	3	65535	-10	10284	-10000	2	747	51900	3	67.5	20	99	0	0	1129	728	0	0961	-5071
    68	10:10:33 AM	805	6004	6004	18	269	1547	5378	-5071	74.2	5801	0	65535	1697	2975	3	65535	-10	10176	-10000	2	699	51903	3	67.5	20	99	0	0	1146	728	0	0961	-5070
    69	10:10:45 AM	817	6004	6004	17	252	1547	5374	-5071	74.2	5801	0	65535	1679	2975	3	65535	-10	10074	-10000	2	653	51910	3	67.6	20	99	0	0	1165	728	0	0961	-5071
    70	10:10:57 AM	829	6004	6004	16	234	1547	5374	-5071	74.5	5801	0	65535	1662	2975	3	65535	-10	9960	-10000	1	602	51908	3	67.6	20	99	0	0	1182	728	0	0961	-5072
    71	10:11:09 AM	841	6004	6004	16	234	1547	5374	-5071	74.5	5801	0	65535	1662	2975	3	65535	-10	9960	-10000	1	602	51908	3	67.6	20	99	0	0	1182	728	0	0961	-5072
    72	10:11:21 AM	853	6004	6004	14	215	1547	5374	-5071	74.6	5801	0	65535	1643	2975	3	65535	-10	9858	-10000	1	553	51908	2	67.6	20	99	0	0	1200	728	0	0961	-5072
    73	10:11:33 AM	865	6004	6004	13	199	1547	5370	-5072	74.7	5801	0	65535	1625	2975	2	65535	-10	9750	-10000	1	508	51920	2	67.8	20	99	0	0	1218	728	0	0961	-5071
    74	10:11:45 AM	877	6004	6004	12	180	1547	5370	-5071	74.7	5801	0	65535	1608	2975	2	65535	-10	9642	-10000	1	459	51920	2	67.9	20	99	0	0	1235	728	0	0961	-5072
    75	10:11:57 AM	889	6004	6004	11	163	1547	5370	-5072	74.8	5801	0	65535	1590	2975	2	65535	-10	9540	-10000	1	414	51920	2	68.0	20	99	0	0	1253	728	0	0961	-5071
    76	10:12:09 AM	901	6004	6004	10	145	1547	5370	-5071	75.0	5805	0	65535	1572	2975	2	65535	-10	9432	-10000	1	365	51918	2	68.3	20	99	0	0	1272	728	0	0961	-5071
    77	10:12:21 AM	913	6004	6004	27	509	1929	5366	-5071	74.9	5801	0	65535	1555	2975	6	65535	-10	9330	-10000	3	1337	51931	6	68.1	20	99	0	0	1289	728	0	0961	-5072
    78	10:12:33 AM	925	6004	6004	26	492	1929	5366	-5072	75.0	5801	0	65535	1536	2975	6	65535	-10	9216	-10000	3	1292	51928	6	68.0	20	99	0	0	1307	728	0	0961	-5072
    79	10:12:45 AM	937	6004	6004	25	474	1929	5366	-5072	75.1	5801	0	65535	1520	2975	6	65535	-10	9108	-10000	3	1243	51928	5	68.3	20	99	0	0	1324	728	0	0961	-5072
    80	10:12:57 AM	949	6004	6004	24	455	1929	5366	-5072	75.1	5801	0	65535	1501	2975	5	65535	-10	9006	-10000	3	1195	51941	5	68.1	20	99	0	0	1342	728	0	0961	-5071
    81	10:13:10 AM	962	6004	6004	23	438	1929	5362	-5071	74.9	5801	0	65535	1483	2975	5	65535	-10	8898	-10000	3	1150	51941	5	67.9	20	99	0	0	1361	728	0	0961	-5071
    82	10:13:22 AM	974	6004	6004	22	420	1929	5362	-5071	74.8	5801	0	65535	1466	2975	5	65535	-10	8790	-10000	3	1101	51941	5	68.1	20	99	0	0	1377	728	0	0961	-5071
    83	10:13:34 AM	986	6004	6004	21	403	1929	5358	-5071	75.1	5801	0	65535	1448	2975	5	65535	-10	8688	-10000	2	1056	51951	5	68.2	20	99	0	0	1396	728	0	0961	-5071
    84	10:13:46 AM	998	6004	6004	20	385	1929	5358	-5072	75.4	5801	0	65535	1431	2975	5	65535	-10	8574	-10000	2	1005	51945	4	68.2	20	99	0	0	1413	728	0	0961	-5073
    85	10:13:58 AM	1010	6004	6004	20	366	1929	5358	-5072	75.1	5801	0	65535	1412	2975	4	65535	-10	8472	-10000	2	957	51951	4	68.3	20	99	0	0	1431	728	0	0961	-5071
    86	10:14:10 AM	1022	6004	6004	19	350	1929	5354	-5072	75.3	5801	0	65535	1394	2975	4	65535	-10	8364	-10000	2	911	51956	4	68.2	20	99	0	0	1449	728	0	0961	-5073
    87	10:14:22 AM	1034	6004	6004	18	331	1929	5354	-5072	75.2	5801	0	65535	1377	2975	4	65535	-10	8256	-10000	2	863	51958	4	68.0	20	99	0	0	1466	728	0	0961	-5071
    88	10:14:34 AM	1046	6004	6004	17	314	1929	5354	-5072	75.3	5801	0	65535	1359	2975	4	65535	-10	8154	-10000	2	818	51968	4	68.3	20	99	0	0	1484	728	0	0961	-5072
    89	10:14:46 AM	1058	6004	6004	17	314	1929	5354	-5072	75.3	5801	0	65535	1359	2975	4	65535	-10	8154	-10000	2	818	51968	4	68.3	20	99	0	0	1484	728	0	0961	-5072
    90	10:14:58 AM	1070	6004	6004	16	296	1929	5350	-5072	75.2	5801	0	65535	1342	2975	3	65535	-10	8046	-10000	2	769	51971	3	68.2	20	99	0	0	1501	728	0	0961	-5072
    91	10:15:10 AM	1082	6004	6004	15	279	1929	5350	-5072	75.2	5801	0	65535	1324	2975	3	65535	-10	7944	-10000	2	724	51971	3	68.3	20	99	0	0	1520	728	0	0961	-5071
    92	10:15:22 AM	1094	6004	6004	14	261	1929	5346	-5072	75.4	5801	0	65535	1305	2975	3	65535	-10	7830	-10000	2	673	51976	3	68.6	20	99	0	0	1538	728	0	0961	-5072
    93	10:15:34 AM	1106	6004	6004	13	242	1929	5346	-5072	75.4	5801	0	65535	1288	2975	3	65535	-10	7728	-10000	1	625	51976	3	68.5	20	99	0	0	1555	728	0	0961	-5072
    94	10:15:46 AM	1118	6004	6004	12	226	1929	5346	-5072	75.5	5801	0	65535	1270	2975	3	65535	-10	7620	-10000	1	580	51989	3	68.6	20	99	0	0	1573	728	0	0961	-5072
    95	10:15:58 AM	1130	6004	6004	11	207	1929	5342	-5072	75.5	5801	0	65535	1253	2975	2	65535	-10	7512	-10000	1	531	51989	2	68.2	20	99	0	0	1590	728	0	0961	-5072
    96	10:16:10 AM	1142	6004	6004	10	190	1929	5338	-5072	75.5	5801	0	65535	1235	2975	2	65535	-10	7410	-10000	1	486	51999	2	68.5	20	99	0	0	1608	728	0	0961	-5072
    97	10:16:22 AM	1154	6004	6004	14	265	2022	5338	-5072	75.5	5801	0	65535	1218	2975	3	65535	-10	7302	-10000	2	692	51999	3	68.6	20	99	0	0	1625	728	0	0961	-5072
    98	10:16:34 AM	1166	6004	6004	13	247	2022	5336	-5072	75.7	5801	0	65535	1200	2975	3	65535	-10	7200	-10000	1	641	52004	3	68.5	20	99	0	0	1644	728	0	0961	-5072
    99	10:16:46 AM	1178	6004	6004	12	230	2022	5336	-5072	75.7	5801	0	65535	1181	2975	3	65535	-10	7086	-10000	1	596	52004	3	68.8	20	99	0	0	1662	728	0	0961	-5072
    100	10:16:58 AM	1190	6004	6004	11	211	2022	5336	-5072	76.0	5801	0	65535	1164	2975	2	65535	-10	6978	-10000	1	548	52004	2	69.0	20	99	0	0	1679	728	0	0961	-5072
    101	10:17:10 AM	1202	6004	6004	10	195	2022	5332	-5072	76.1	5801	0	65535	1146	2975	2	65535	-10	6876	-10000	1	503	52011	2	69.1	20	99	0	0	1697	728	0	0961	-5073
    102	10:17:22 AM	1214	6004	6004	10	198	2044	5332	-5073	76.2	5801	0	65535	1128	2974	2	65535	-10	6762	-10000	1	515	52022	2	69.1	20	99	0	0	1714	728	0	0961	-5073
    103	10:17:34 AM	1226	6004	6004	9	181	2044	5328	-5073	76.1	5801	0	65535	1110	2974	2	65535	-10	6660	-10000	1	469	52022	2	69.1	20	99	0	0	1732	728	0	0961	-5073
    104	10:17:46 AM	1238	6004	6004	9	169	2050	5324	-5073	76.0	5801	0	65535	1093	2975	2	65535	-10	6558	-10000	1	439	52034	2	69.1	20	99	0	0	1751	728	0	0961	-5072
    105	10:17:58 AM	1250	6004	6004	8	151	2050	5324	-5073	76.1	5801	0	65535	1076	2975	2	65535	-10	6456	-10000	1	389	52034	2	69.0	20	99	0	0	1768	728	0	0961	-5073
    106	10:18:10 AM	1262	6004	6004	7	134	2050	5320	-5072	76.2	5805	0	65535	1057	2975	2	65535	-10	6342	-10000	1	360	52034	2	69.3	20	99	0	0	1786	728	0	0961	-5072
    107	10:18:22 AM	1274	6004	6004	6	123	2057	5320	-5073	76.5	5805	0	65535	1041	2975	1	65535	-10	6234	-10000	1	312	52042	1	69.4	20	99	0	0	1803	728	0	0961	-5072
    108	10:18:34 AM	1286	6004	6004	6	123	2057	5320	-5073	76.5	5805	0	65535	1041	2975	1	65535	-10	6234	-10000	1	312	52042	1	69.4	20	99	0	0	1803	728	0	0961	-5072
    109	10:18:46 AM	1298	6004	6004	6	106	2057	5316	-5073	76.7	5805	0	65535	1022	2975	1	65535	-10	6132	-10000	1	266	52052	1	69.1	20	99	0	0	1821	728	0	0961	-5073
    110	10:18:58 AM	1310	6004	6004	5	92	2062	5312	-5073	76.5	5805	0	65535	1003	2974	1	65535	-10	6018	-10000	1	236	52052	1	69.3	20	99	0	0	1838	728	0	0961	-5073
    111	10:19:10 AM	1322	6004	6004	4	74	2062	5312	-5073	76.5	5807	0	65535	986	2974	1	65535	-10	5916	-10000	0	188	52062	1	69.1	20	99	0	0	1856	728	0	0961	-5073
    112	10:19:22 AM	1334	6004	6004	4	64	2069	5308	-5073	76.2	5807	0	65535	968	2974	1	65535	-10	5808	-10000	0	162	52075	1	69.2	20	99	0	0	1875	728	0	0961	-5071
    113	10:19:34 AM	1346	6004	6004	3	46	2069	5308	-5072	76.3	5807	0	65535	951	2974	1	65535	-10	5694	-10000	0	111	52072	0	69.3	20	99	0	0	1892	728	0	0961	-5072
    114	10:19:46 AM	1358	6004	6004	2	29	2069	5304	-5073	76.7	5807	0	65535	932	2974	0	65535	-10	5592	-10000	0	66	52082	0	69.4	20	99	0	0	1910	728	0	0961	-5073
    115	10:19:58 AM	1370	6004	6004	4	81	2139	5300	-5073	76.6	5807	0	65535	916	2974	1	65535	-10	5484	-10000	0	202	52093	1	69.4	20	99	0	0	1927	728	0	0961	-5073
    116	10:20:10 AM	1382	6004	6004	3	62	2139	5300	-5073	76.5	5807	0	65535	897	2974	1	65535	-10	5382	-10000	0	155	52095	1	69.4	20	99	0	0	1945	728	0	0961	-5072
    117	10:20:22 AM	1394	6004	6004	4	84	2178	5296	-5072	76.7	5807	0	65535	880	2975	1	65535	-10	5280	-10000	0	213	52105	1	69.4	20	99	0	0	1964	728	0	0961	-5072
    118	10:20:34 AM	1406	6004	6004	4	66	2178	5292	-5073	76.9	5807	0	65535	863	2975	1	65535	-10	5178	-10000	0	165	52113	1	69.4	20	99	0	0	1980	728	0	0961	-5073
    119	10:20:46 AM	1418	6004	6004	4	85	2214	5292	-5073	77.0	5807	0	65535	845	2975	1	65535	-10	5070	-10000	1	215	52118	1	69.6	20	99	0	0	1999	728	0	0961	-5072
    120	10:20:58 AM	1430	6004	6004	4	67	2214	5286	-5073	77.0	5807	0	65535	828	2975	1	65535	-10	4956	-10000	0	165	52128	1	69.7	21	99	0	0	2016	728	0	0961	-5073
    121	10:21:10 AM	1442	6004	6004	3	50	2214	5286	-5073	77.1	5807	0	65535	809	2975	1	65535	-10	4854	-10000	0	120	52128	1	70.0	21	99	0	0	2034	728	0	0961	-5073
    122	10:21:22 AM	1454	6004	6004	4	87	2269	5282	-5073	77.2	5807	0	65535	792	2974	1	65535	-10	4740	-10000	1	217	52138	1	69.8	21	99	0	0	2051	728	0	0961	-5073
    123	10:21:34 AM	1466	6004	6004	3	68	2269	5278	-5074	77.1	5807	0	65535	773	2974	1	65535	-10	4638	-10000	0	170	52146	1	69.6	21	99	0	0	2069	728	0	0961	-5074
    124	10:21:46 AM	1478	6004	6004	5	94	2312	5274	-5073	77.0	5807	0	65535	756	2975	1	65535	-10	4536	-10000	1	238	52158	1	69.9	21	99	0	0	2088	728	0	0961	-5073
    125	10:21:58 AM	1490	6004	6004	4	76	2312	5270	-5073	77.1	5807	0	65535	739	2975	1	65535	-10	4428	-10000	0	191	52169	1	70.1	21	99	0	0	2104	728	0	0961	-5073
    126	10:22:10 AM	1502	6004	6004	3	59	2312	5266	-5073	77.4	5807	0	65535	721	2975	1	65535	-10	4326	-10000	0	146	52179	1	70.3	21	99	0	0	2123	728	0	0961	-5073
    127	10:22:22 AM	1514	6004	6004	3	59	2312	5266	-5073	77.4	5807	0	65535	721	2975	1	65535	-10	4326	-10000	0	146	52179	1	70.3	21	99	0	0	2123	728	0	0961	-5073
    128	10:22:34 AM	1526	6004	6004	5	98	2369	5262	-5073	77.4	5805	0	65535	703	2974	1	65535	-10	4206	-10000	1	245	52186	1	70.1	21	99	0	0	2140	728	0	0961	-5074
    129	10:22:46 AM	1538	6004	6004	4	79	2369	5258	-5074	77.3	5805	0	65535	684	2974	1	65535	-10	4104	-10000	0	200	52196	1	69.8	21	99	0	0	2158	728	0	0961	-5074
    130	10:22:58 AM	1550	6004	6004	5	106	2413	5254	-5073	76.9	5805	0	65535	666	2974	1	65535	-10	3996	-10000	1	269	52209	1	69.9	21	99	0	0	2176	728	0	0961	-5072
    131	10:23:10 AM	1562	6004	6004	4	88	2413	5250	-5073	76.8	5805	0	65535	649	2974	1	65535	-10	3894	-10000	1	222	52222	1	69.9	21	99	0	0	2193	728	0	0961	-5072
    132	10:23:22 AM	1574	6004	6004	5	102	2444	5246	-5072	76.8	5805	0	65535	632	2975	1	65535	-10	3792	-10000	1	258	52237	1	69.9	21	99	0	0	2212	728	0	0961	-5072
    133	10:23:34 AM	1586	6004	6004	4	84	2444	5240	-5072	77.1	5805	0	65535	615	2975	1	65535	-10	3684	-10000	0	211	52245	1	69.9	21	99	0	0	2228	728	0	0961	-5073
    134	10:23:46 AM	1598	6004	6004	3	66	2444	5232	-5073	77.0	5807	0	65535	597	2975	1	65535	-10	3582	-10000	0	161	52265	1	69.6	21	99	0	0	2247	728	0	0961	-5073
    135	10:23:58 AM	1610	6004	6004	4	90	2487	5232	-5073	76.9	5805	0	65535	578	2975	1	65535	-10	3468	-10000	1	230	52275	1	69.8	21	99	0	0	2265	728	0	0961	-5073
    136	10:24:10 AM	1622	6004	6004	3	73	2487	5224	-5073	76.7	5807	0	65535	560	2975	1	65535	-10	3360	-10000	0	183	52285	1	69.7	21	99	0	0	2283	728	0	0961	-5073
    137	10:24:22 AM	1634	6004	6004	5	106	2538	5216	-5073	76.9	5805	0	65535	542	2974	1	65535	-10	3252	-10000	1	268	52306	1	69.7	21	99	0	0	2300	728	0	0961	-5073
    138	10:24:34 AM	1646	6004	6004	4	89	2538	5212	-5073	77.0	5805	0	65535	524	2974	1	65535	-10	3132	-10000	1	218	52316	1	70.0	21	99	0	0	2319	728	0	0961	-5073
    139	10:24:46 AM	1658	6004	6004	6	130	2597	5204	-5073	77.0	5805	0	65535	505	2974	2	65535	-10	3030	-10000	1	327	52336	1	69.9	21	99	0	0	2337	728	0	0961	-5074
    140	10:24:58 AM	1670	6004	6004	5	112	2597	5200	-5073	77.2	5805	0	65535	489	2974	1	65535	-10	2922	-10000	1	280	52351	1	69.9	21	99	0	0	2354	728	0	0961	-5073
    141	10:25:10 AM	1682	6004	6004	4	95	2597	5194	-5073	77.3	5805	0	65535	470	2974	1	65535	-10	2820	-10000	1	236	52372	1	70.1	21	99	0	0	2372	728	0	0961	-5073
    142	10:25:22 AM	1694	6004	6004	5	109	2630	5186	-5073	77.6	5805	0	65535	453	2975	1	65535	-10	2718	-10000	1	274	52379	1	70.2	21	99	0	0	2391	728	0	0961	-5073
    143	10:25:34 AM	1706	6004	6004	4	91	2630	5178	-5074	77.7	5805	0	65535	436	2975	1	65535	-10	2616	-10000	1	227	52399	1	70.4	21	99	0	0	2407	728	0	0961	-5074
    144	10:25:46 AM	1718	6004	6004	4	91	2630	5178	-5074	77.7	5805	0	65535	436	2975	1	65535	-10	2616	-10000	1	227	52399	1	70.4	21	99	0	0	2407	728	0	0961	-5074
    145	10:25:58 AM	1730	6004	6004	3	65	2621	5170	-5074	77.8	5807	0	65535	418	2975	1	65535	-10	2508	-10000	0	162	52420	1	70.5	21	99	0	0	2426	728	0	0961	-5074
    146	10:26:10 AM	1742	6004	6004	2	47	2621	5162	-5074	77.9	5807	0	65535	401	2975	1	65535	-10	2394	-10000	0	113	52450	1	70.7	21	99	0	0	2443	728	0	0961	-5074
    147	10:26:22 AM	1754	6004	6004	2	30	2621	5152	-5074	77.9	5807	0	65535	382	2975	0	65535	-10	2292	-10000	0	70	52465	0	70.8	21	99	0	0	2461	728	0	0961	-5074
    148	10:26:34 AM	1766	6004	6004	2	27	2636	5144	-5074	78.2	5807	0	65535	364	2975	0	65535	-10	2184	-10000	0	62	52486	0	70.8	21	99	0	0	2479	728	0	0961	-5074
    149	10:26:46 AM	1778	6004	6004	1	8	2636	5136	-5074	78.4	5807	0	65535	347	2975	0	65535	-10	2082	-10000	0	16	52516	0	71.1	21	99	0	0	2496	728	0	0961	-5074
    150	10:26:58 AM	1790	6004	6004	1	22	2667	5122	-5074	78.4	5807	0	65535	329	2975	0	65535	-10	1974	-10000	0	52	52541	0	71.3	21	99	0	0	2515	728	0	0961	-5074
    151	10:27:10 AM	1802	6004	6004	1	4	2667	5110	-5074	78.6	5807	0	65535	312	2975	0	65535	-10	1866	-10000	0	6	52572	0	71.5	21	99	0	0	2531	728	0	0961	-5074
    152	10:27:22 AM	1814	6004	6004	2	49	2729	5100	-5074	78.6	5807	0	65535	294	2975	1	65535	-10	1764	-10000	0	121	52607	1	71.5	21	99	0	0	2550	728	0	0961	-5074
    153	10:27:34 AM	1826	6004	6004	2	31	2729	5086	-5074	78.5	5807	0	65535	275	2975	0	65535	-10	1650	-10000	0	73	52633	0	71.3	21	99	0	0	2568	728	0	0961	-5074
    154	10:27:46 AM	1838	6004	6004	1	12	2729	5074	-5074	78.6	5807	0	65535	258	2975	0	65535	-10	1548	-10000	0	27	52673	0	71.2	21	99	0	0	2585	728	0	0961	-5075
    155	10:27:58 AM	1850	6004	6004	1	1	2735	5060	-5075	78.5	5807	0	65535	239	2974	0	65535	-10	1434	-10000	0	0	52696	0	70.9	21	99	0	0	2603	728	0	0961	-5075
    156	10:28:10 AM	1862	6004	6004	0	0	2735	5044	-5074	78.2	5807	0	65535	239	2974	0	65535	-10	1434	-10000	0	0	52750	0	71.0	21	99	0	0	2620	728	0	0961	-5074
    157	10:28:23 AM	1875	6004	6004	0	0	2766	5024	-5074	78.3	5807	0	65535	209	2975	0	65535	-10	1254	-10000	0	0	52790	0	70.9	21	99	0	0	2639	728	0	0961	-5074
    158	10:28:35 AM	1887	6004	6004	0	0	2766	5006	-5074	78.5	5807	0	65535	209	2975	0	65535	-10	1254	-10000	0	0	52833	0	71.0	21	99	0	0	2657	728	0	0961	-5075
    159	10:28:47 AM	1899	6004	6004	0	0	2805	4986	-5075	78.6	5807	0	65535	169	2974	0	65535	-10	1014	-10000	0	0	52884	0	71.0	21	99	0	0	2674	728	0	0961	-5074
    160	10:28:59 AM	1911	6004	6004	0	0	2805	4968	-5075	78.7	5807	0	65535	169	2974	0	65535	-10	1014	-10000	0	0	52930	0	71.1	21	99	0	0	2692	728	0	0961	-5075
    161	10:29:11 AM	1923	6004	6004	0	0	2805	4942	-5075	78.9	5807	0	65535	169	2974	0	65535	-10	1014	-10000	0	0	53006	0	71.3	21	99	0	0	2709	728	0	0961	-5076
    162	10:29:23 AM	1935	6004	6004	0	0	2848	4916	-5075	78.8	5807	0	65535	127	2975	0	65535	-10	762	-10000	0	0	53062	0	71.4	21	99	0	0	2727	728	0	0961	-5074
    163	10:29:35 AM	1947	6004	6004	0	0	2848	4916	-5075	78.8	5807	0	65535	127	2975	0	65535	-10	762	-10000	0	0	53062	0	71.4	21	99	0	0	2727	728	0	0961	-5074
    164	10:29:47 AM	1959	6004	6004	0	0	2848	4888	-5075	78.8	5807	0	65535	127	2975	0	65535	-10	762	-10000	0	0	53128	0	71.3	21	99	0	0	2746	728	0	0961	-5075
    165	10:29:59 AM	1971	6004	6004	0	0	2890	4858	-5075	79.0	5807	0	65535	84	2974	0	65535	-10	504	-10000	0	0	53209	0	71.3	21	99	0	0	2763	728	0	0961	-5074
    166	10:30:11 AM	1983	6004	6004	0	0	2890	4828	-5075	78.9	5807	0	65535	84	2974	0	65535	-10	504	-10000	0	0	53287	0	71.6	21	99	0	0	2781	728	0	0961	-5075
    167	10:30:23 AM	1995	6004	6004	0	0	2890	4788	-5075	79.0	5807	0	65535	84	2974	0	65535	-10	504	-10000	0	0	53386	0	71.7	21	99	0	0	2798	728	0	0961	-5075
    168	10:30:35 AM	2007	6004	6004	0	0	2932	4746	-5075	79.2	5807	0	65535	42	2974	0	65535	-10	252	-10000	0	0	53498	0	71.6	21	99	0	0	2816	728	0	0961	-5075
    169	10:30:47 AM	2019	6004	6004	0	0	2932	4700	-5075	79.1	5807	0	65535	42	2974	0	65535	-10	252	-10000	0	0	53612	0	71.6	21	99	0	0	2835	728	0	0961	-5075
    170	10:30:59 AM	2031	6004	6004	0	0	2873	4648	-5075	79.0	5807	0	65535	101	2974	0	65535	-10	606	-10000	0	0	53754	0	71.7	21	99	0	0	2749	728	0	0961	-5074
    171	10:31:11 AM	2043	6004	6004	0	0	2873	4586	-5074	79.0	5807	0	65535	101	2974	0	65535	-10	606	-10000	0	0	53922	0	71.4	21	99	0	0	2768	728	0	0961	-5074
    172	10:31:23 AM	2055	6004	6004	0	0	2881	4510	-5074	79.2	5807	0	65535	93	2974	0	65535	-10	558	-10000	0	0	54112	0	71.9	21	99	0	0	2750	728	0	0961	-5074
    173	10:31:35 AM	2067	6004	6004	0	0	2881	4418	-5075	79.5	5807	0	65535	93	2974	0	65535	-10	558	-10000	0	0	54354	0	71.9	21	99	0	0	2768	728	0	0961	-5076
    174	10:31:47 AM	2079	6004	6004	0	0	2881	4310	-5075	79.6	5807	0	65535	93	2974	0	65535	-10	558	-10000	0	0	54630	0	71.9	21	99	0	0	2786	728	0	0961	-5075
    175	10:31:59 AM	2091																																	Possible Error-See error log
    176	10:32:11 AM	2103																																	Possible Error-See error log
    177	10:32:23 AM	2115																																	Possible Error-See error log
    178	10:32:35 AM	2127	6004	6004	0	0	2941	4704	8	80.1	9806	0	65535	0	2941	65535	22058	-10	0	-10000	0	0	35	65535	71.8	21	99	0	0	0	16254	0	0961	13
    179	10:32:47 AM	2139	6014	6014	0	0	2941	4770	9	79.6	9806	0	65535	0	2941	65535	19607	-10	0	-10000	0	0	21	65535	71.6	21	99	0	0	0	16254	0	0961	9
    4251.cauldron_2013_11_26_charge_01.log
    4667.cauldron_2013_11_26_charge_01.pdf
    2772.cauldron_2013_11_26_discharge_01.pdf
  • Liat,
    I reviewed the gg file and recommend a couple of changes before you run the optimization cycles.
    • Decrease the Flash Update voltage to 2000mV.
    • Disable the FConvEn bit in the Pack Cfg B register during the optimization cycles.
    • Be sure to send IT Enable command to enable Impedance Track.
    Tom
  • got it, thanks
    Billy
