bq24735 multi-cell charging
Other Parts Discussed in Thread: BQ20Z65, BQ24735
I have a battery packs of 3 cells welded on a PCB which has the gas gauge chip bq20z65.
I will use a smart charger using the chip bq24735. It's in a good way to work now.
But I wonder if it's possible two have, for example, 3 smart battery chargers using then 3 different bq24735 but with one power supply with of course a high debit of current ? What do you think of such a solution ?
Moreover, in the bq24735 we must set the 'Charge Options register' after each power on reset, is there a mean to have a permanent register ? because the smart battery can't send at the beginning of each charge the options..
Alex
