bq24297
With no charger connected, and the boost enabled, does the Vsys voltage stay above the Vsys min setting when the battery falls below the Vsys min level and remains above the Vlowbat voltage?
If so is this support over the specified load current ranges?
  • Hello Rod,
    When there is no charger connected and operating only on battery, the BATFET directly connects the battery to the system, therefore Vsys will be almost the same as the battery voltage (few millivolts below the battery voltage). There is no boost, just a direct connection.
