Other Parts Discussed in Thread: TPS60400
I wish to separate a single voltage source into a positive and negative voltage source and ground. I want to use the configuration as sources for several OP-AMP's. I know the concept behind virtual ground but is it as simple as just using a shunt voltage reference component?
I am basically looking for an effective, simple way to make a virtual ground.
