Help with BQ2461xEVM
Other Parts Discussed in Thread: BQ24617
I have 2S3P Li-Ion battery pack with 3 pin connector (+, - and 10k NTC) to serve as backup power supply in device. I want to use BQ24617 for charging that battery with 12V adapter. In BQ24617 datasheet it is explained how to configure circuit for specified battery. Firstly, I wanted to use BQ2461xEVM to test that circuit with our battery before implementing this charger in our system. So before buying it, I have some questions:
What is configurable in BQ2461xEVM?
Can I change resistors R25 and R28 to set preferable battery charge voltage?
Can I change resistors to change iput voltages on ISET1, ISET2 or ACSET?
Can I use this in testing phase, connecting my device to system output, battery and adapter on its designed place?
Thanks for all your help,
Nenad
