Other Parts Discussed in Thread: BQ30Z55
Hi Friend,
I met a issue is bq30z55 V0.36 Ra table not update after did full learning, but the RU and Gauge function are enable, follow is the GG file, could you please help to command what the problem is? Whether there is something wrong in setting? Thanks.
Suren
[Header]
bq EVSW Version = 0.9.90
DeviceName = bq30z55R3 v0.36
Time = 2013/12/25 ¤U¤È 03:59:38
[State(Gas Gauging)]
Qmax Cell 0 = 2304
Qmax Cell 1 = 2308
Qmax Cell 2 = 2309
Qmax Cell 3 = 2200
Qmax Pack = 2304
Update Status = 06
Cell 0 Chg Voltage at EoC = 4200
Cell 1 Chg Voltage at EoC = 4200
Cell 2 Chg Voltage at EoC = 4201
Cell 3 Chg Voltage at EoC = 0
Current at EoC = 92
Avg I Last Run = -503
Avg P Last Run = -553
Delta Voltage = 2
Max Avg I Last Run = -505
Max Avg P Last Run = -625
[IT Cfg(Gas Gauging)]
Load Select = 7
Load Mode = 0
Ra Filter = 50.0
Ra Max Delta = 15
Design Resistance = 97
Reference Grid = 4
Resistance Parameter Filter = 65142
Term Voltage = 9000
Term Voltage Delta = 300
User Rate-mA = 0
User Rate-cW = 0
Reserve Cap-mAh = 30
Reserve Cap-cWh = 0
Remcap Smoothing Filter = 250
Fast Scale Start SOC = 10
[Current Thresholds(Gas Gauging)]
Dsg Current Threshold = 100
Chg Current Threshold = 50
Quit Current = 10
[R_a0(Ra Table)]
Cell0 R_a flag = 0055
Cell0 R_a 0 = 87
Cell0 R_a 1 = 101
Cell0 R_a 2 = 105
Cell0 R_a 3 = 130
Cell0 R_a 4 = 88
Cell0 R_a 5 = 101
Cell0 R_a 6 = 116
Cell0 R_a 7 = 112
Cell0 R_a 8 = 120
Cell0 R_a 9 = 114
Cell0 R_a 10 = 102
Cell0 R_a 11 = 131
Cell0 R_a 12 = 214
Cell0 R_a 13 = 483
Cell0 R_a 14 = 934
[R_a1(Ra Table)]
Cell1 R_a flag = 0055
Cell1 R_a 0 = 78
Cell1 R_a 1 = 92
Cell1 R_a 2 = 99
Cell1 R_a 3 = 125
Cell1 R_a 4 = 84
Cell1 R_a 5 = 97
Cell1 R_a 6 = 113
Cell1 R_a 7 = 107
Cell1 R_a 8 = 115
Cell1 R_a 9 = 111
Cell1 R_a 10 = 99
Cell1 R_a 11 = 127
Cell1 R_a 12 = 211
Cell1 R_a 13 = 501
Cell1 R_a 14 = 970
[R_a2(Ra Table)]
Cell2 R_a flag = 0055
Cell2 R_a 0 = 87
Cell2 R_a 1 = 101
Cell2 R_a 2 = 106
Cell2 R_a 3 = 132
Cell2 R_a 4 = 90
Cell2 R_a 5 = 103
Cell2 R_a 6 = 119
Cell2 R_a 7 = 115
Cell2 R_a 8 = 122
Cell2 R_a 9 = 117
Cell2 R_a 10 = 104
Cell2 R_a 11 = 134
Cell2 R_a 12 = 219
Cell2 R_a 13 = 515
Cell2 R_a 14 = 993
[R_a3(Ra Table)]
Cell3 R_a flag = FF55
Cell3 R_a 0 = 72
Cell3 R_a 1 = 84
Cell3 R_a 2 = 96
Cell3 R_a 3 = 166
Cell3 R_a 4 = 99
Cell3 R_a 5 = 104
Cell3 R_a 6 = 138
Cell3 R_a 7 = 95
Cell3 R_a 8 = 87
Cell3 R_a 9 = 92
Cell3 R_a 10 = 107
Cell3 R_a 11 = 136
Cell3 R_a 12 = 209
Cell3 R_a 13 = 522
Cell3 R_a 14 = 1009
[R_a0x(Ra Table)]
xCell0 R_a flag = 0000
xCell0 R_a 0 = 87
xCell0 R_a 1 = 101
xCell0 R_a 2 = 105
xCell0 R_a 3 = 130
xCell0 R_a 4 = 88
xCell0 R_a 5 = 101
xCell0 R_a 6 = 116
xCell0 R_a 7 = 112
xCell0 R_a 8 = 120
xCell0 R_a 9 = 114
xCell0 R_a 10 = 102
xCell0 R_a 11 = 131
xCell0 R_a 12 = 214
xCell0 R_a 13 = 498
xCell0 R_a 14 = 963
[R_a1x(Ra Table)]
xCell1 R_a flag = 0000
xCell1 R_a 0 = 78
xCell1 R_a 1 = 92
xCell1 R_a 2 = 99
xCell1 R_a 3 = 125
xCell1 R_a 4 = 84
xCell1 R_a 5 = 97
xCell1 R_a 6 = 113
xCell1 R_a 7 = 107
xCell1 R_a 8 = 115
xCell1 R_a 9 = 111
xCell1 R_a 10 = 99
xCell1 R_a 11 = 127
xCell1 R_a 12 = 211
xCell1 R_a 13 = 516
xCell1 R_a 14 = 999
[R_a2x(Ra Table)]
xCell2 R_a flag = 0000
xCell2 R_a 0 = 87
xCell2 R_a 1 = 101
xCell2 R_a 2 = 106
xCell2 R_a 3 = 132
xCell2 R_a 4 = 90
xCell2 R_a 5 = 103
xCell2 R_a 6 = 119
xCell2 R_a 7 = 115
xCell2 R_a 8 = 122
xCell2 R_a 9 = 117
xCell2 R_a 10 = 104
xCell2 R_a 11 = 134
xCell2 R_a 12 = 219
xCell2 R_a 13 = 530
xCell2 R_a 14 = 1022
[R_a3x(Ra Table)]
xCell3 R_a flag = FFFF
xCell3 R_a 0 = 72
xCell3 R_a 1 = 84
xCell3 R_a 2 = 96
xCell3 R_a 3 = 166
xCell3 R_a 4 = 99
xCell3 R_a 5 = 104
xCell3 R_a 6 = 138
xCell3 R_a 7 = 95
xCell3 R_a 8 = 87
xCell3 R_a 9 = 92
xCell3 R_a 10 = 107
xCell3 R_a 11 = 136
xCell3 R_a 12 = 209
xCell3 R_a 13 = 522
xCell3 R_a 14 = 1009
[Manufacturer Data(System Data)]
ManufacturerInfo =
[Integrity(System Data)]
Data Flash Checksum = 0000
[Data(SBS Configuration)]
Remaining AH Cap. Alarm = 220
Remaining WH Cap. Alarm = 244
Remaining Time Alarm = 10
Initial Battery Mode = 0081
Design Voltage = 11100
Specification Information =
Manufacture Date = 21-Dec-2013
Serial Number = 0001
Cycle Count = 2
Cycle Count Percentage = 80
Max Error Limit = 100
Design Capacity mAh = 2200
Design Capacity cWh = 2442
Manufacturer Name =
Device Name =
Device Chemistry = LION
[FD(SBS Configuration)]
Set Voltage Threshold = 3000
Clear Voltage Threshold = 3100
Set % RSOC Threshold = 0
Clear % RSOC Threshold = 5
[FC(SBS Configuration)]
Set Voltage Threshold = 4200
Clear Voltage Threshold = 4100
Set % RSOC Threshold = 100
Clear % RSOC Threshold = 95
[TDA(SBS Configuration)]
Set Voltage Threshold = 3200
Clear Voltage Threshold = 3300
Clear % RSOC Treshold = 15
[TCA(SBS Configuration)]
[Max Error(SBS Configuration)]
Time Cycle Equivalent = 24
Cycle Delta = 0.05
[CUV(Protections)]
Threshold = 2700
Delay = 2
Recovery = 3000
[CUVC(Protections)]
Threshold = 2900
Delay = 0
Recovery = 3000
[COV(Protections)]
Threshold Low Temp = 4250
Threshold Standard Temp = 4250
Threshold High Temp = 4250
Threshold Rec Temp = 4250
Delay = 2
Recovery Low Temp = 4100
Recovery Standard Temp = 4100
Recovery High Temp = 4100
Recovery Rec Temp = 4100
[OCC1(Protections)]
Threshold = 3000
Delay = 2
[OCC2(Protections)]
Threshold = 8000
Delay = 0
[OCC(Protections)]
Recovery Threshold = 0
Recovery Delay = 30
[OCD1(Protections)]
Threshold = -4000
Delay = 45
[OCD2(Protections)]
Threshold = -8000
Delay = 0
[OCD(Protections)]
Recovery Delay = 30
[OLD(Protections)]
Threshold = 03
Delay = 07
Latch Limit = 0
Counter Dec Delay = 10
Recovery = 30
Reset = 15
[SCC(Protections)]
Threshold = 22
Latch Limit = 0
Recovery = 30
Reset = 15
[SCD1(Protections)]
Threshold = 82
[SCD2(Protections)]
Threshold = E7
[SCD(Protections)]
Latch Limit = 0
Recovery = 30
Reset = 15
[OTC(Protections)]
Threshold = 65.0
Delay = 3
Recovery = 45.0
[OTD(Protections)]
Threshold = 75.0
Delay = 3
Recovery = 55.0
[OTF(Protections)]
Threshold = 80.0
Delay = 0
Recovery = 65.0
[HWD(Protections)]
Delay = 10
[PTO(Protections)]
Charge Threshold = 2000
Suspend Threshold = 1800
Delay = 18000
Reset = 2
[CTO(Protections)]
Charge Threshold = 2500
Suspend Threshold = 2000
Delay = 54000
Reset = 2
[OC(Protections)]
Threshold = 300
Recovery = 2
RSOC Recovery = 90
[CHGV(Protections)]
Threshold = 500
Delay = 30
Recovery = -500
[CHGC(Protections)]
Threshold = 500
Delay = 2
Recovery = 100
[CUV(Permanent Fail)]
Threshold = 2000
Delay = 5
[COV(Permanent Fail)]
Threshold = 4400
Delay = 10
[CUDEP(Permanent Fail)]
Threshold = 2500
Delay = 0
[OTCE(Permanent Fail)]
Threshold = 80.0
Delay = 10
[OTF(Permanent Fail)]
Threshold = 100.0
Delay = 0
[QIM(Permanent Fail)]
Delta Threshold = 2200
Delay = 2
[CB(Permanent Fail)]
Max Threshold = 240
Delta Threshold = 40
Delay = 2
[VIMR(Permanent Fail)]
Check Voltage = 3700
Check Current = 20
Delta Threshold = 200
Delta Delay = 30
Duration = 100
[VIMA(Permanent Fail)]
Check Current = 50
Delta Threshold = 300
Delay = 2
[IMP(Permanent Fail)]
Max Threshold = 400
Ra Update Counts = 2
[CD(Permanent Fail)]
Threshold = 0
Delay = 2
[CFET(Permanent Fail)]
OFF Threshold = 20
OFF Delay = 2
[DFET(Permanent Fail)]
OFF Threshold = -20
OFF Delay = 2
[TH(Permanent Fail)]
ADC Delay = 10
[FUSE(Permanent Fail)]
Threshold = 20
Delay = 2
[AFER(Permanent Fail)]
Threshold = 100
Delay Period = 2
Compare Period = 5
[AFEC(Permanent Fail)]
Threshold = 100
Delay Period = 5
[2LVL(Permanent Fail)]
Delay = 2
[OCECO(Permanent Fail)]
Threshold = 5000
Delay = 2
[Device Status Data(PF Status)]
Safety Alert 0-15 = 0000
Safety Status 0-15 = 0000
PF Alert 0-15 = 0000
PF Status 0-15 = 0000
Safety Alert 16-31 = 0000
Safety Status 16-31 = 0000
PF Alert 16-31 = 0000
PF Status 16-31 = 0000
Operation Status 0-15 = 0000
Operation Status 16-31 = 0000
Charging Status 0-15 = 0000
Charging Status 16-23 = 00
Gauging Status = 0000
[Device Voltage Data(PF Status)]
Cell Voltage 0 = 0
Cell Voltage 1 = 0
Cell Voltage 2 = 0
Cell Voltage 3 = 0
Battery Direct Voltage = 0
Pack Voltage = 0
[Device Current Data(PF Status)]
Current = 0
[Device Temperature Data(PF Status)]
Internal Temperature = -273.2
External 1 Temperature = -273.2
External 2 Temperature = -273.2
[Device Gauging Data(PF Status)]
Cell0 Dod0 = 0
Cell1 Dod0 = 0
Cell2 Dod0 = 0
Cell3 Dod0 = 0
Passed Charge = 0
[AFE Regs(PF Status)]
AFE Status = 00
AFE State Control = 00
AFE Control = 00
AFE Output Status = 00
AFE Function Control = 00
AFE Cell Select = 00
AFE OCDV = 00
AFE OCDT = 00
AFE SCC = 00
AFE SCD1 = 00
AFE SCD2 = 00
AFE REF TRIM = 00
[Safety Status(Black Box)]
1st Status Status 0-15 = 0000
1st Safety Status 16-31 = 0000
1st Time to Next Event = 0
2nd Safety Status 0-15 = 0000
2nd Safety Status 16-31 = 0000
2nd Time to Next Event = 0
3rd Safety Status 0-15 = 0000
3rd Safety Status 16-31 = 0000
3rd Time to Next Event = 0
[PF Status(Black Box)]
1st PF Status 0-15 = 0000
1st PF Status 16-31 = 0000
2nd PF Status 0-15 = 0000
2nd PF Status 16-31 = 0000
3rd PF Status 0-15 = 0000
3rd PF Status 16-31 = 0000
[Voltage(Lifetimes)]
Max Cell Voltage 0 = 3620
Max Cell Voltage 1 = 3620
Max Cell Voltage 2 = 3620
Max Cell Voltage 3 = 0
Min Cell Voltage 0 = 3620
Min Cell Voltage 1 = 3620
Min Cell Voltage 2 = 3620
Min Cell Voltage 3 = 0
Max Delta Cell Voltage = 0
[Current(Lifetimes)]
Max Charge Current = 0
Max Discharge Current = 0
Max Avg Dsg Current = 0
Max Avg Dsg Power = 0
[Safety Events(Lifetimes)]
No Of Cov Events = 0
Last Cov Event = 0
No Of Cuv Events = 0
Last Cuv Event = 0
No Of Ocd1 Events = 0
Last Ocd1 Event = 0
No Of Ocd2 Events = 0
Last Ocd2 Event = 0
No Of Occ1 Events = 0
Last Occ1 Event = 0
No Of Occ2 Events = 0
Last Occ2 Event = 0
No Of Old Events = 0
Last Old Event = 0
No Of Scd Events = 0
Last Scd Event = 0
No Of Scc Events = 0
Last Scc Event = 0
No Of Otc Events = 0
Last Otc Event = 0
No Of Otd Events = 0
Last Otd Event = 0
No Of Otf Events = 0
Last Otf Event = 0
[Charging Events(Lifetimes)]
No Valid Charge Term = 0
Last Valid Charge Term = 0
[Gauging Events(Lifetimes)]
No Of Qmax Updates = 0
Last Qmax Update = 0
No Of Ra Updates = 0
Last Ra Update = 0
No Of Ra Disable = 0
Last Ra Disable = 0
[Power Events(Lifetimes)]
No Of Shutdowns = 0
[Cell Balancing(Lifetimes)]
Cb Time Cell 0 = 0
Cb Time Cell 1 = 0
Cb Time Cell 2 = 0
Cb Time Cell 3 = 0
[Temperature(Lifetimes)]
Max Temp Cell = 16
Min Temp Cell = 15
Max Delta Cell Temp = 78
Max Temp Int Sensor = 17
Min Temp Int Sensor = 15
Max Temp Fet = 0
[Time(Lifetimes)]
Total Fw Runtime = 30
Time Spent In UT = 0
Time Spent In LT = 0
Time Spent In STL = 30
Time Spent In RT = 0
Time Spent In STH = 0
Time Spent In HT = 0
Time Spent In OT = 0
[Fuse(Settings)]
PF Fuse 0-15 = 0013
PF Fuse 16-31 = 0003
Min Blow Fuse Voltage = 6000
[Manufacturing(Settings)]
Manufacturing Status = 01FE
[Protection(Settings)]
Enabled Protections 0-15 = 3557
Enabled Protections 16-31 = 0000
[Permanent Failure(Settings)]
Enabled PF 0-15 = 0013
Enabled PF 16-31 = 0003
[Configuration(Settings)]
Protection Configuration = 02
Temperature Configuration = 0402
Charging Configuration = 5D
System Configuration = 0226
Gauging Configuration = 000F
Sbs Configuration = 20
Sbs Data Config. 0-15 = 0CCC
Sbs Data Config. 16-23 = CC
[AFE(Settings)]
AFE State Control = 10
[Power(Power)]
Valid Update Voltage = 7500
[Shutdown(Power)]
Shutdown Voltage = 2500
Shutdown Time = 10
PF Shutdown Voltage = 2500
PF Shutdown Time = 10
Charger Present Threshold = 3000
[Sleep(Power)]
Sleep Current = 10
Voltage Time = 5
Current Time = 20
Wake = 00
[Ship(Power)]
Delay = 5
[Temperature Ranges(Advanced Charge Algorithm)]
T1 Temp = 0
T2 Temp = 10
T5 Temp = 20
T6 Temp = 30
T3 Temp = 45
T4 Temp = 55
Hysteresis Temp = 1
[Low Temp Charging(Advanced Charge Algorithm)]
Voltage = 4200
Current Low = 220
Current Med = 220
Current High = 220
[Standard Temp Charging(Advanced Charge Algorithm)]
Voltage = 4200
Current Low = 1100
Current Med = 1100
Current High = 1100
[High Temp Charging(Advanced Charge Algorithm)]
Voltage = 4200
Current Low = 1100
Current Med = 1100
Current High = 1100
[Rec Temp Charging(Advanced Charge Algorithm)]
Voltage = 4200
Current Low = 1100
Current Med = 1100
Current High = 100
[Pre-Charging(Advanced Charge Algorithm)]
Current = 220
[Maintenance Charging(Advanced Charge Algorithm)]
Current = 44
[Voltage Range(Advanced Charge Algorithm)]
Charging Voltage Low = 2500
Charging Voltage Med = 3600
Charging Voltage High = 4000
Charging Voltage Hysteresis = 0
[Termination Config(Advanced Charge Algorithm)]
Charge Term Taper Current = 110
Charge Term Voltage = 130
[Cell Balancing Config(Advanced Charge Algorithm)]
Bal Time/mAh Cell 0 = 367
Bal Time/mAh Cell 1-3 = 514
Min Start Balance Delta = 3
Relax Balance Interval = 18000
Min Rsoc for Balancing = 80
[Charging Rate of Change(Advanced Charge Algorithm)]
Current Rate = 1
Voltage Rate = 1
[Charge Loss Compensation(Advanced Charge Algorithm)]
CCC Current Threshold = 3520
CCC Voltage Threshold = 4200
[Voltage(Calibration)]
Cell Scale 0 = 20538
Cell Scale 1 = 20579
Cell Scale 2 = 20647
Cell Scale 3 = 20517
Pack Gain = 53136
BAT Gain = 49147
[Current(Calibration)]
CC Gain = 1.85
Capacity Gain = 551701
[Current Offset(Calibration)]
CC Offset = -7338
Coulomb Counter Offset Samples = 64
Board Offset = 0
[Temperature(Calibration)]
Internal Temp Offset = 4.4
External1 Temp Offset = -3.7
External2 Temp Offset = -2.9
[Internal Temp Model(Calibration)]
Int Coeff 1 = 0
Int Coeff 2 = 0
Int Coeff 3 = -11136
Int Coeff 4 = 5754
Int Minimum AD = 0
Int Maximum Temp = 5754
[Cell Temperature Model(Calibration)]
Coeff a1 = -14520
Coeff a2 = 23696
Coeff a3 = -20298
Coeff a4 = 28073
Coeff a5 = 865
Coeff b1 = -694
Coeff b2 = 1326
Coeff b3 = -3880
Coeff b4 = 5127
Rc0 = 11703
Adc0 = 11703
Rpad = 0
Rint = 0
[Fet Temperature Model(Calibration)]
Coeff a1 = -14520
Coeff a2 = 23696
Coeff a3 = -20298
Coeff a4 = 28073
Coeff a5 = 865
Coeff b1 = -694
Coeff b2 = 1326
Coeff b3 = -3880
Coeff b4 = 5127
Rc0 = 11703
Adc0 = 11703
Rpad = 0
Rint = 0
[Filter(Calibration)]
Cell Voltage 1 = 145
Cell Voltage 2 = 145
Cell Voltage 3 = 145
Cell Voltage 4 = 145
Pack Voltage Out = 10
Direct Battery Voltage = 10
Summed Battery Voltage = 145
Cell Temperature = 145
FET Temperature = 145
[Current Deadband(Calibration)]
Deadband = 5
Coulomb Counter Deadband = 34
