In the Mistral development kit for AM3874 is used TPS659113.
According to the description pin V5IN consumes current less than 1mA, other supply pins can be powered from 3.3V.
Is it possible to implement the scheme with a chip TPS659113 using only 3.3V power supply?
If not, could you recommend a solution for the AM3874 processor and memory DDR3 using only 3.3V external power supply?
