I like to use 4 primary cell batteries in serie, typ LiMnO2, and measure the fuel gauge. The design capacity of one cell is 12 Ah. Operating temperature is -40°…70 °C. Can you recommend a TI part?
I have the bq34z100EVM Eval.kit with the EV2300.
I started the Eval. SW: bq34z100 Evaluation Software (Rev. A)
How can I simply initialize the Pack Capacity of my primary cells (LiMnO2) which is 12Ah.
I tried to set in the DataRAM the Full Charge Capacity and the Remaining Capacity, but I couldn’t change it to my primary battery pack data.
Can you indicate how to do this, step by step? Thanks
Bruno,
You can following the Design Steps guidelines in the bq34z100 datasheet. (pg 28) You will set the Design Capacity and QMAX for your cells during this process. FCC and RM are simulation values that are leveraged from the Design Capacity and QMAX.
Tom
