My customer evaluate LM5045 in voltage mode and have some problems.
He said jitter occured in HO1/LO1(HO2/LO2) and it seems proportional to load current.
I can see the description about jitter in datasheet P.30.
"The two ground pins (AGND,PGND) must be connected together directly underneath the IC with a short, direct connection, to avoid jitter due to relative ground bounce."
Is there anthing else general workaround to avoid jitter?
Your help would be appreciate.
Yaita
