LM2577-ADJ quick check
Other Parts Discussed in Thread: LM2577, LM2733
Hello everyone,
I was hoping some of you experienced designers could look at my circuit and check whether my calculations seem reasonable. It is my first time designing step-up converter, so just to be sure.
My goal is to generate 48V from 9V, as clean as possible (audio use), with maximum current 30mA. I know the lm2577 seems a bit of an overkill, but I haven't found any other solution yet.
I know the circuit will produce actually 50V, will work on that later - but that is not the critical part. I am particularly not completely sure about L, R(C) and C(C).
Thank you very much for any input on the circuit!
Jonas
