I'm trying to make a simple power-limiting circuit to bring up a 0.25F cap bank to 60V. In order to achieve this, I need to make the cap on the TIMER pin a couple orders of magnitude larger - testing with an AN-1522 eval board.
I've put 200uF between TIMER and ground, which now means that we don't produce a fault during the in-rush limiting, however it how takes around 3 minutes to get through the 'Insertion Time'.
Is there a nice way to either decrease the Insertion Time or to eliminate it all together?
Thanks!
