If we don't need the LP# function of TPS51367,
Can the LP# pin tied to the VREF directly for disabling it?
Go
Hi, Mr. Go,
When the IC is enabled, LP# pin outputs 1uA current. If LP# is connected VREF, VREF output current is decreased by 1uA. As long as that reduction does not affect any other characteristics such as REFIN voltage, you can connect VREF to LP# pin to disable LP mode.
S. Ishikawa
