how to achieve desired uvlo settings in TPS92314
The turn on threshold of VCC UVLO is about 26V@25C and turn off threshold is about 13V@25C. There will be minor changes in these value due to temperature and process. Please refer to data sheet pg.3, 5 and 9 for details.
Victor
Hi Victor
Thanks...
we have got UVLO at 60V AC to 80V AC Input & but we need the UVLO at 120V-150V AC INPUT FOR 39W application( o/p is 60v 650ma ).
What should we do for that.
Could you attach your schematic? I think the value of the resistors connected to VCC and the AUX winding have something to do with your UVLO.
Victor
If you set the turn ON and OFF at same level, the power supply will turn on and off at threshold voltage. We won’t do that in designing an AC/DC power supple generally.
Is there any reason you need to do so?
Victor
