Hi -
Hopefully simple questions!
In Figure 15 of the datasheet for the LM1084 LDO regulator (http://www.ti.com/lit/ds/symlink/lm1084.pdf), I assume that the Y-axis (Power) is the amount that can be dissipated before the regulator is at risk of damage.
Assuming the regulator is damaged by dissipating too much power at high temp, what are the most likely manifestations of a failure?
No voltage transferred to Vout?
No voltage regulation on Vout?
Would the failure be catastrophic / permanent?
Or is the part potentially protected by current limiting circuitry and simply requires Overload Recovery (power recycle on the regulator)?
Or is the failure non-catastrophic and simply decreases the expected useful life / reliability?
Thanks!
Dan
