I would like to keep "CC Delta " and " Remaining Capacity" values after calibration.
Currently, this values are reset after diconneting the battery from the gauge more than one minute.
How to avoid the gauge data reset ?
thank you
thank you
Thank you for your previous answer.
What is the max voltage on the pin "RBI" of BQ2084 ?
Thibault
You normally just place a capacitor on the RBI pin, so I am assume that you want to apply an external voltage. In that case the RBI voltage should be set to 3.3V typ, 3.6V max and 4.1V absolute max.
