UCC 2895 - external control of the oscillation frequency
Other Parts Discussed in Thread: UCC2895
I would like that UCC2895 oscillation frequency to be controlled in a wide range by an external circuit.
Can use an external clock signal (on SYNC pin) to active control the oscillation frequency in the wide range  ( 10kHz - 250kHz ) ?
In this situation how should be connected pins RT and CT ?
Thank You !
