LM25118 noice
Other Parts Discussed in Thread: LM25118
Dear support TI.
We make  one dc - dc converter with the LM25118, the drive works fine.
The problem is that it generates a lot of interference on the FM band, we tested different EMi filters but not do away with noise.
What can be the cause?.
Best regards
  • Hi
    EMI filter might not remove the noise perfectly, but at least you should be able to see an improvement.
    If you could not see any improvement with a filter, this means your filter was not working well or that was not the noise source.
    Usually, MOSFET gate resistance, Qrr, Quality of PC board layout affects FM band noise.
