HI,
I am using TPS65137AEVM board for testing. I faced some problem related with output voltage while i was testing the board.
When I connect resistor across the positive and negative output voltage, and supply input voltage, the device is not working as it is supposed to work.
But when I first supply input voltage and then connect resistor a across the positive and negative output voltage, the device is working properly. the resistor I used is 75ohm.
I couldn't understand what the problem is. From the datasheet, I read about SHORT CIRCUIT PROTECTION function.
Even if I toggled the CTRL pin high and low as the datasheet said, the problem still persists.
Is there anybody to help me? please.
