I understand that the buck converter TPS54620 can be used in an inverting configuration by grounding the Vout side of the Inductor of the circuit and the Vgnd ref of the chip will be inverted hence negative. Can you apply this same technique for the TPS53353? Is there any app note that shows how to use the TPS53353 in an buck inverting configuration?
Thank you
