bqEASY step 2B "maximum taper current"
Other Parts Discussed in Thread: BQ27541
If the charger tapers the current from 1.2A down to 50mA what is the maximum taper current? Is it 1.2A or 50mA or slightly above 50mA?
What is this value used for?
My guesstimate is it is used for counting total charging cycles. The value should be around what the taper end current is in maximum. I'm using 55mA atm. for 50mA end taper current. Is this totally wrong?
