The specification said maximum capacity for the bq2084 ist 15000mAh.
What will happen if i use cells more than 15Ah?
Greetings
Norbert
Greetings
Norbert
Hi Tom,
thank you for the answer!
I found the maximum capacity information on this page:
http://www.ti.com/lsds/ti/power-management/battery-fuel-gauge-products.page
In the Datasheet i didn´t find any limitation.
Thank you!
Norbert
Dear Tom,
where did you find the maximum capacity of 65000mAh?
I only found the maximum range of 65535..!??
After a few cycles with more than 15000mAh everything is fine at the moment.
Thanks!
Norbert
