There's a typo on Table 3. Standard RSET and RRT Resistor Values of the LMZ35003 datasheet.
For 5.5V output, RSET needs to be 58k7, not 48k7. 48k7 gives 4.6V output (which is also consistent with Eq. 1)
Hi Enrique,
Thanks a lot for letting us know the error in the LMZ35003 datasheet. You were right about the Rset value for 5.5Vout. The Rset should be 59.0Kohm (E96 standard value). We will submit the correction request.
Again, thanks for your time and help.
Hung
