bq29209 cell balancer
I am having a problem understanding the cell balancing IC datasheet. specifically the Recommended Cell Balancing Configuration table listed on page 5 of the datasheet. It lists the ICB values with a specified RCB value from the table. It then goes on to show formulas for ICB1 and ICB2 but i cant seem to work backwards to get the values listed in the table. Is there some other formula missing?
Also in the Customer test mode section it states you enter this state by having VDD set to 9.5v above VC2 but in the application circuit it has VC2 tied thru a resistor to VDD. Do you have more information on the CTM mode? I assume i do this with the batteries disconnected. Thanks.
