Dear All,
Good day!
I am doing a Power supply (+5V / 3A) for GSM modem (SIM900) based application. Regarding the LM2576 Input and output capacitors in the application diagram shows that, 100uF and output side is 1000uF.
Generally the power supplies having less capacitance value than the input side to avoid the back flow of charged supply through the regulator.
But in the case of LM2576 Typical application (for 5VDC / 3A) is showing that input side 100uF and output side 1000uF. TI gives always right solution for all their products. However, please clarify my doubt in this regards.
Thank you all.
Ramesh Duraisamy.
